engine coatings?
bowtiebuba
stangs hate supras
Sep 1, 2005
207
marion iowa
where do you guys get your engine coatings also whats your opinion on them? do you think there good or just a waste?
Halsupramk3
444
Mississippi
I used Swain tech. You can talk to the head man Dan. I have my pistons tops with gold coat and the skirts pc9 i think. i also had the exhaust ports of the head and back side of the exhaust valves coated to keep out heat. Oh and the combustion chambers. that way all the areas that have heat are coated. i have enclosed some pics. I do think that coating can keep heat out of the engine components and so it goes out the exhaust ports which is why i coated the chambers. if you coat the piston why not coat the chambers too.
Swain tech website is
swaintech.com
I will try to posts some pics.
Halsupramk3
444
Mississippi
Swain tech does. They say theirs is not subject to flaking off like some coatings do. There is some good info at swaintech.com but of course it is to sell you on their coatings. they cost a little more but i do think their coatings are better than just ceramic coating. I would really like to coat my downpipe with their white lightning coating.
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
Indianapolis, Indiana
www.apeserver.com
I should take some pictures of my pistons that I had done by HPC AFTER 70k miles.
I had the skirts done with an oil holding coating, and the tops with their piston top coating. The coating was worn 90° opposite of hte pin bores, and IIRC the piston tops still looked good.
