emissions advice
robbo185
693
Chicago
Well today i decided to take everyones favorite test before i go back to school saturday, and well i failed with flying colors.
here are the results
HC
standard- .80 me---9.70
CO
standar - 15.0 me---3701
major mods are 550cc injectors, maft, safc, walbro255, 3inch turbo back with magnaflow cat, tanabe exhaust. Nonbypassed/drilled out jtube
Ideas to correct problem:
put on stock bov with greddy or get recirculation kit
set maft to 440cc injector size
search for boost leaks
drill/bypass J tube
any other ideas/suggestions??
8,873
If you set the piggy back to smaller injectors with out using smaller injectors, the pulse width increase making you even richer.
Suggestion is to list the rest of the emission trace.
You have way to much fuel for your upgrades. And you might have other problems.
8,873
Based on the info you provided, that is my only answer right now. Does it smoke when you are driving?
robbo185
693
Chicago
no smoke at all
cruise a/f---14.5ish if on throttle holding speed....
wot-11.8
idle-11.2-12.5ish
robbo185
693
Chicago
Nick M said:
Idle is way high. Are you getting a 51? And put the stock cat on before you retest.
ill check codes in the morning
my guess with the idle would have to be fuel pressure due to the jpipe...ill get back to you after i check codes
