I'm trying to help another member here(Dragk913) with his idle issues in my spare time(which isn't much). 90 N/A Auto.
No vacuum leaks, smoke tested to make sure. I tested the ISC, and it works. I checked for power, and its getting 12v. to the 2 middle pins. It seems that it isn't getting a ground signal to the other 4 pins to operate the motor. Not really sure how to test for ground pulses. I think they would be to fast for a test light, but maybe I could use a noid light instead? I actually used the test procedure to set the ISC with the car running(harness dis-connected) so that it would idle decent. If I'm reading the diagram correctly, EO1 and EO2 are the ground for the ecu. Are those the grounds that bolt to the intake? I've already been through all the grounds in the engine compartment, and they're all in good shape. I know I'm missing something....
Any help would be greatly appreciated
C.J.
C.J.
