Im 5 days into this electrical nightmare. First the fuel pump left me then after I got it fixed I drove it home. I turned it off like normal idle was good then suddenly it just cut like I pulled the plug. (Yes I have a turbo timer) tried to start it back up and its spins over but never catches. No poot, pop, nothing. Noid light shows no pulse. Test light shows power at the injector on both pins. I have spark. I have continuity from the ecu to the injector however what strikes me as odd is I have continuity from one pin across all pins??
Ex. Probe pin 2 on ecu (inj no1) and have continuity on injector 2??
I have been through all the different diagrams but cant find the smoking gun here. Have checked with two ecu and both do the same thing. Some explain to me whats going on here. Whats right and wrong and why.
