EGT readings....
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
well i searched around and didnt find much, im wondering what safe EGTS would be. i have my probe in the 5th runner of the stock manifold, runing a 11.9-12.1 air fuels i see temps as high as 1550. how hot is safe? btw my timing i believe is off, i think im only running 5 degrese instead of 10. im gona check it out tomarro and see if it makes a diffrence.
whats safe on a stock motor?? a motor with forged pistons???
Red Dragon
Keep That on the Down Low
Jan 5, 2006
318
Austin, TX
you don't want to go much higher than that, if any. And I wouldn't spend too much time up that high either. My EGT's can get that hot as well, but as soon as it gets around 1500-ish,. maybe a bit higher, I usually shut her down. I'm measuring at the collector with a single tap.
isnms
United States of America
Oklahoma
i80.photobucket.com
Here is some of the information I have come up with, researching EGTs. Keep in mind which links are talking about pump gas and which are talking about alcohol or race gas.
So far, I think safe for pump gas is ~11:1 a/f and ~1500°F egt.
http://forums.nasioc.com/forums/archive/index.php/t-74745.html
http://www.autronic.com/technical_data_files/antilag.pdf#search="timing egt higher"
http://forums.nasioc.com/forums/archive/index.php/t-222226.html
70mph = ~1300-1325F
80mph = ~1350-1400F
90mph = ~1400-1450F
http://www.angelfire.com/pro2/rst/air_fuel_tuning_tips.htm
Your target AFR should be around 14.7:1 in vacuum, around 12.5:1 at static, and around 11.5-11.0:1 as you approach your peak boost level. This will achieve the best fuel economy while supporting for lots of airflow.
If the temperature probe for the EGT Gauge is placed on the exhaust manifold, the temperature should NEVER exceed 1650°F (I would recommend using 1600°F as a max just to be safe). If your car is Turbocharged, and your probe is placed on the Downpipe (after the turbo), use 1400°F as your max safe temp (1450°F is cutting it dangerous).
One of the main side effects of changing the airflow with a SAFC, is the profound effect it has on timing. The timing map in the ECU is set up as such: the ECU looks at the engine speed and the airflow (actually the airflow per rev, but we wont go there right now), and then finds the point on the timing map. The timing map is just set up like a spreadsheet, with the columns representing either engine speed or airflow, and the rows representing the other. The tendency of the timing map is that lower airflow (less load on the motor) gets more timing advance. This is for a couple reasons, but generally lower load means less heat and less cylinder pressure, which means you can use more timing advance to get the mixture to combust at the correct point. The effect this has is that if you reduce the amount of airflow that the ECU sees, it will move down on the timing map, and you will get more advance.
You need to be very careful with this. Not only do you get more advance at WOT, but you also get more advance at cruise and part throttle. In most cases, the WOT knock that can be caused by too much advance can be tuned out, but the knock caused at part throttle and when the turbo is spooling can’t always be.
http://www.eng-tips.com/viewthread.cfm?qid=153619&page=7
1) Detonation
2) AFR
3) Exhaust Temps
To increase the torque at a given engine speed (and therefore power) the amount of air in the combustion chamber must be increased. However as with everything there is a compromise: -
As the airmass per stroke increases so does the tendency to detonate.
To stop this detonation the spark must be retarded.
As the spark is retarded the exh temps increase.
As the temps increase the AFR must be reduced.
This 'richening' can only continue until such time as rich misfire occurs - or no more torque is produced because of the extreme retarded spark.
I use both egt and a/f ratios. You can have high egt's whether you are rich or lean. It is important that you know which side of the a/f range you are so you know how to correct it. Mine peaks at ~730C at high rpm, light load, cruising. That's when egt's are high. Under boost, mine stays pretty much closer to 700C or cools down a bit with 12.5:1 a/f. Keep in mind, egt's get higher with too much timing retard, not enough fuel, and too much fuel. So, if you are satisfied with your a/fs and you still think that your EGT is too high for your comfort, try looking at your ignition timing, a couple degrees of change brought mine down by ~30C. In my case, there are other variables that can compensate for many things, one example is adding fuel when egt's reach ~750C and at the same time limitting the boost pressure. HTH. Ron
timing egt higher
http://www.iwsti.com/forums/archive/index.php/t-31041.html
Leaning out AFR increases EGTs as does reducing timing.
http://www.ca.dsm.org/cgi/ultimatebb.cgi?ubb=get_topic;f=16;t=000317
Basically you would start off on the rich side (on your afc) and start leaning out until your EGT gets closer to 1550F. At around that point you know you're getting as much timing advance as you can, with the least amount of knock as possible. If your EGTs start climbing, it means your timing is being retarded due to the knock sensor picking up detonation.
high EGT = retarded ignition; low EGT = advanced ignition
http://dragstuff.com/techarticles/reading-alcohol-spark-plugs.html
The fuel mixture and the ignition timing are totally intertwined as to the effecting the appearance of the spark plug ring at the of the threads and the EGT values. Changing the fuel to air ratio and changing the ignition will both change the combustion chamber temperature. The leaner the mixture or the more advanced the ignition the higher the combustion chamber temperature and the richer the mixture or the more retarded the ignition the lower the combustion chamber temperature. Remember the EGT sensor is outside the combustion chamber so it is only reading the exhaust gas/flame temperature. The more the ignition advance the lower the EGT and more the ignition is retarded the higher the EGT. This opposite effect is caused moving the heat or the flame out of the chamber into the exhaust with a retarded ignition and raising the temperature of the EGT. So having a high EGT because of retarded ignition can and will show less heat in the spark plugs.
It is highly recommended to pick a maximum ignition timing point that is known to be good for your particular engine setup and tune the mixture for that point. This way the tune-up is safe and you can retard the ignition to pull out power without drastically changing your fuel tune-up. You can always go back to the maximum power ignition point without damaging the engine.
http://www.pgmfi.org/twiki/bin/view/Library/WebHome
Advance timing, EGTs get cooler.
Retard timing, EGTs get hotter.
http://www.roadraceengineering.com/newafc.htm
If you are running too lean for the boost and octane you have in the tank, you will get knock or pre-ignition. The knock sensor bolted to the engine block will pick up this "pinging" sound long before you can hear it inside the car. When under higher boost, there is almost always small amounts of knock. At these small amounts of knock the ECU will continue to advance timing normally. At mid knock levels the ECU will hold timing and if it gets too high or rises quickly, the ECU will begin to retard timing if not pull it all the way back to zero. You can hear the exhaust note change when the timing goes away. It will turn deeper , almost rumbly sounding. When the timing is retarded, the ignition process happens so late that the flame front shoots out the exhaust port when the exhaust valve opens and blows still expanding, really hot gas directly onto the EGT probe. So internally the pistons are barely warm, but the exhaust manifold and turbo get real hot. This is the reason we recommend not running EGTs higher than 900 degrees C. That is the point that timing retard is usually driving the EGTs up. Not that immediate damage is being done, it is just that you are no longer making additional power above that temperature and there is no benefit to running there.
http://forums.evolutionm.net/archive/index.php/t-161019.html
EGT's depend alot on your timing and AFR, if your running very rich, you may still have burning fuel in your exhaust leading to high EGT's.. Too lean and you get very high EGT's due to complete burn in the combustion chamber, too much timing and you get high EGT's due to compressing expanding exhaust gases (detonation too) too little timing, and you get burning fuel out the exhaust.. the difference is the high EGT's due to late timing or rich condition is the fuel burning outside the combustion chamber.. but high EGT"s due to too much timing or too little fuel, result in conditions INSIDE the combustion chamber that can do damage..
http://www.migweb.co.uk/forums/vauxhall_archive/t-81619.html
Picked this up off the DSM tuners forum in the States! John A will appreciate this one! ( This guy has years of experience in turbo tuning Jap engines and some whipper snappers were trying to tell him his business, the Tefal head puts em right:D )
I'm going to go a little more in depth, since some people are still having a hard time grasping this concept, despite the fact that it has been discussed to death on various forums for at least the last 3 years that I can recall.
People think that high EGTs equal high combustion temps, which would indicate a lean mixture. So when they see high temps, the typically add fuel. And when it is low they lean out. This method of tuning is flawed for various reasons, and I will touch on all of them.
Myth number one: The internal engine parts will melt at over 900 degrees C or 1650 F. Here is some big news. Combustion temps are over 2000 degrees and can reach 3 to 4 thousand. So why dont the parts melt? Just a few quick reasons. One is heat sink capacity. Two is heat transfer from the piston to the cylinder wall through the rings. Three is heat transfer to the oil that is splashed up or squirted on the piston and other parts. Four is heat transfer into the cooling system through the head or block. In fact, so much heat is taken out through these methods that by the time the combustion gasses get to the manifold and EGT probe, temp is down to 900 c or 1650 f
;o) Some heat is also lost in the conversion of heat energy to mechanical energy in the form of gas expansion. So that myth goes down the terlet.
Myth number two. If EGT is high the mixture is too lean. Well what happens when the mixture is (way) too rich? It is still burning as the exhaust valve opens. Fire in the manifold WILL heat up the probe. Not rocket science. I have seen a dozen people add fuel and add fuel and EGT temps dont go down.
Lean out to where they are supposed to be though and its all normal again. I know it goes against the "Internet Laws of EGT Guages," but its the truth.
Also, what happens when the mixture is WAY too lean? Temps go down. Why?
Less fuel to support combustion. It is entirely possible to be so lean that combustion temps drop so low that there isnt enough heat energy to increase pressure enough to cause knock. I have seen this happen on my car after a baro wire mod gone wrong.
Myth number three. If EGT is too low, the mixture is too rich. Not necessarily, though this is way more possible than vice versa. It depends entirely on the setup. The more knock prone you are the more fuel you need.
That slight difference in EGT temp will show itself if and only if you are getting maximum timing advance for your setup.
So what does the EGT tell you? I've said it a thousand times before, as have hundreds of other DSMers, but ponder this. You are knocking. For ANY reason, not just lean mixture. The knock sensor picks this up and reports to the ECU. Now this may be hard for some of you to believe apparently, but when the ECU senses knock, it pulls timing. The amount of timing it pulls will vary based on the "normal" knock sensor noise threshold, how strong the signal is, and how long it has been going on, among other factors. The ECU comes up with a kncok retard value, and that amount of timing is pulled back from where the full timing would be based on the timing map you are currently on. Here is what I mean by this. The timing map you are currently on is based on airflow mostly, but also coolant temp and intake temp and other factors. This map or table includes timing values for each rpm point.
So lets say for where your car curently is, you are on a map that says at this rpm maximum advance would be 17 degrees. But knock retard is 3 degrees.
What will your timing be? Get out the calculators. 14 degrees is what you will get.
Now what does retarded timing have to do with this... If the timing is retarded enough, as in LESS ADVANCE, the ignition event occurs LATER in the combustion cycle, in degrees of crank rotation. If the mixture is ignited late enough, it is still burning as the exhaust valve opens. Refer to "Myth number two." Fire in the hole will heat up the probe. THIS IS WHY high EGT temps mean that you are getting knock and reduced timing advance. Read it a few times. Let it soak in.
Furthermore, the amount of change in EGT temps per change in air fuel ratio is MINOR, while conversely, the change in exhaust gas temps is SUBSTANTIAL when the timing is retarded and there is fire on the probe. Why? The increased heat caused by a leaner mixture is mostly absorbed by the motor or converted to additional mechanical engery. The latter is the cause for the increase in power when you can lean out without knocking (<- key phrase, pay attention). By the time the combustion gasses get to the probe, the difference is now slight. In contrast, the difference in temps between normal exhaust gasses and fire is very significant and it show up easily on the guage. Now it is important to remember that the higher combustion temperatures caused by a lean mixture not only increase mechanical output, but increase a motor's (or cylinder's) tendency to knock. And again, this knock brings on timing retard, which brings on fire in the hole, which brings on a high EGT temp reported on the guage. THIS IS WHY poeple confuse high EGT temps caused by mixture with high EGT temps caused by knock.
Because both usually happen at the same time when fuel tuning. You can also have one without the other, as is the case with mechanical knock or phantom knock.
So now that we got that straight...
Other reasons why EGT is not a good way to tune, without a logger. The ideal temperature will vary with EVERY car and EVERY setup and EVERY set of conditions. I do upwards of 300 drag passes a year and have clearly observed and datalogged this. With that established, the only way to find the ideal EGT temp for your setup/car/conditions/gear is to datalog to see what your timing is. At the point you develop knock you can get an idea of where you want EGT. The problem is, as I stated above, when you have full timing the difference in temperature effected by changes in air fuel ratio is very small. This is complicated even more by my next point:
EGT guages are not very accurate, nor are they precise. Yet another reason to need a datalogger to verify and validate what you are seeing on the EGT guage... The probes are slow to respond, and I will explain why. The rate at which an object changes temperature varies directly as the the difference between the temperature of the object and the temperature of its surroundings. In this case the object is the probe, and the surroundings are the exhaust gasses. What this tells us is that the greater the difference in the temp of the probe and the temp of the gasses the greater the RATE OF CHANGE of temperature. So as the temp of the probe rises (or falls) to match the temp of the exhaust gasses, the difference between the two temps is decreasing. This slows the rate of change. And the cycle continues... So as you can see this is not a linear function, its a curve. This is why poeple often say that the guage reacts slow, or to estimate how fast the needle is moving to estimate where it would really be if it was faster, etc. This is a fundamental problem for both accuracy (especially) and precision (not so much). Another problem is that in general they tend to fail on the low side, meaning they will read colder than what the case really is. So you'll lean out more and more. What happens then is you seem knock "easier" and the tuning window (based on EGT temps) becomes very small and touchy. I have been there, and done that. This is not the way I would choose to tune my car But if so many people insist this is the way to go, what can I say.
This is not rocket science. This is not new information. It has been documented, measured, qualified, quantified, and posted about for as long as I have been into DSMs. But not enough apparently. I am going to copy this into a file on my PC, so I can paste it into the next 500 posts I read about this. If I have to type all of this again I'm gonna snap...
The link to the whole thread can be supplied!:p
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
damn.... that was some serious informative post lol. i am thinkin that its my ignition bieng retarted 5 degrees causing the egts to be so hot. my air fuels are pretty consistent 11.8 to 12.1 so im pretty sure im good there, its just my egts at around 1550 thats really hot lol. but those temps are up at 4 and 5krpm so idk maybe its more forgiving at the higher rpms.
im gona try to reset my timing tomarro and make a couple of runs.
inline6
Whistle>Whine
Sep 22, 2005
208
SoCal
This is very good information. I was always under the impression that advanced timing created higher egt. So basically, retarded timing moves the heat from the combustion chamber to the exhaust manifold instead from the later ignition in the cycle.
What kind of problems are associated with high EGT's then?
Assuming AFR is spot on, too advanced timing = detonation, while too retarded timing = high egts, head damage?
I always thought high egts meant you were closer to detonation. Unless too advanced yields high egts and too retarded does also?
How would you go about adjusting timing on the street to get in the correct range? I'd like to try it out before using a dyno so I know what i'm doing on a dyno when I go and not waste an hour+.
chriso
Supranian
Bay Area, CA
Whoa, Izzy - you are the man !!! Move over Jeff Lange we have a new encyclopedia in the house :biglaugh:
This is some awesome information. Thanks for the gain adjustment spreadsheets also, that is some great work.
isnms
Oklahoma
i80.photobucket.com
Thanks guys. That was my research when I decided to add egt to my worksheets and because I lost a cylinder, probably because of timing, cause my a/f was ~11.5:1. So I am installing an egt probe to watch temp.
chriso - Thanks; Which worksheet did you get? Would you give me some feedback after you've used it a while?
edit:never mind which one, I guess you probably got the on for maftpro :), well let me know if it is useful.
edit: oh, I didn't loose the cylinder using the worksheets. I had a rebic lc installed.
isnms
Oklahoma
i80.photobucket.com
I finally got some EGT readings :)
at 75mph cruise I average 14.7A/F at ~1370°F
on a wot run with high 10 A/F and ~10psi boost, I hit 1580°F
These are the first EGT readings I've been able to log. I'll continue to log more and see how it goes as I tune my safr.
My probe is in the manifold at the collector before the turbo.
edit: added a/f on cruise and probe location.
87targa
200
Utah
man seems like everyone egts are high. when i'm at cruise (75 mph) i'm at 1287 F, 14.5 AF. peak boost (17 psi)is at 1350 F peak egt, 11 AF. when cruising at 90 mph i get egts of 1300-1400 F. but could my egts be because it's tapped into number 6 runner?
oh egts also very on terrane. up hill will be higher than down and flat surfaces.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
yea everyone seems higher then me, i rarely go above 1200 when driving normall, its only when it really boosts that i break 1300. still highest to date is 1550 at about 12.(1-4):1 af
inline6
Whistle>Whine
Sep 22, 2005
208
SoCal
Location of the probe makes a big difference in temps, so depending on where yours is located could be part of the difference.
aljordan
LEADED FUEL ONLY
Jul 14, 2005
466
Indianapolis, Indiana
www.apeserver.com
retarding igntion timing will greatly effect EGT. Really.. a/f isn't an influence in EGT. The reason why people will see higher EGTs when leaning a car is due to the car seeing knock, and retarding the timing. WHen it pulls timing, EGT's riase.
EGT's are raised due to the point at which the heat is released in the combustion cycle. It is released later and later, and eventually, the exhuast will be open when heat is released (I'm being very simplictic here).
o
EGT's and air to fuel ratios.. really have no correlation.
You must spread some Reputation around before giving it to isnms again.
Whoa! Very good info!
Keep in mind though, A/F ratios have the largest effect on EGT ;)
89Turbo
804
Portland
so 1400 cruising at 65-75 seems a little high, what could be causing this on my motor? mods in sig, or are there to many options, or maybe because its in the 6th runner of the manifold?
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
but im in the 5th runner, it doesnt get much hotter then where it is now, i never go over 1200 unless im at or above like 5 inhg vac.
adn i cant set my timing to 10 degrees is guess its because i had the head milled or osmething throwing the cam timing off slightly. i can get it to 5 degrees but if i move it one more tooth the lowest i can set it is like 15. anyone else have this problem?
87targa
200
Utah
o
your probably right about A/F not effecting EGTs. but i did notice that when i was running pig rich (9:1) my egts never went above 1000 F. but when i leaned it out to 11:1 the EGTs went up. now that could be due to timing but i have no idea. all i know is that my base timing is at 10 deg.
Now there's probably a thread somewhere on SM about where to put egt probe. i was talking to my buddy and he said to put the egt probe furthest away from your fuel inlet side (where the fuel comes into the fuel rail). basicly, put the egt probe on the side where your fuel return is. he says that's supposed to give you your highes egt reading. now he has a dsm.
on supras, what i've read was that it's supposed to go on your number six runner. the one on the fuel inlet side.
