EGR removal, just 2nuts/2bolts?
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
I was feeling around tonight to guage how much of a PITA removing the EGR was going to be. I can't see in so i could only feel around. I see the two bolts connected to the intake plenum, and from what i could feel i found 2 nuts on the side the EGR connects to the heads. Besides obvious vacuum hoses, is that it for removal?
Also, i'm removing it because it leaks very steadily. I was just going to epoxy around the crimp on it and the screws on the bottom since thats mostly where i heard the leaks...is that a terrible idea or A-ok?
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
theres 2 ports for the EGR.. one goes through the lower I/M into the head, and one is on the Upper I/M.
You will need EGR blockoff plates, as well as gaskets. (make some from gasket material.
disconnecting the vacuum lines is pretty much self and visual explanitory
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
I'm not removing it permanently, theres benefits to having it there. I just need to get it off to seal it from leaking.
Im just asking if there are only 2 nuts and 2 bolts then some vacuum lines...or are there more bolts/nuts i couldn't find??
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
Nomad707 said:
nope thats it.. i dont see why you would want to keep it though.. other then smog laws.
why not save some gas and keep your temps down? there's not really a big negative to the egr
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
to my understanding thats what the evap system does not the egr (why JDM engines have the evap system and not the egr, people just take evap off with the egr usually and confuse them, exhaust gas recirculation sounds less friendly than fuel evaporative emission control) he also said he is just temporarily taking it off.
yet someone correct me if im wrong :)
tlo86
Jul 24, 2005
3,914
Colorado
jetjock said:
^ Couldn't be more wrong. How's that?
i just figured from a mix of previous posts and wild guessing. quite the combo?:biglaugh:
why would jdm engines come without this? lower emissions, better gas mileage, cooler temps at the cost of a couple of horsepower? maybe? or is there more to it than just that?
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
this will help with your 'guessing' :1zhelp: http://www.supramania.com/forums/showthread.php?t=27185&highlight=EGR*+removal :1zhelp:
read it, learn it, love it, live it :) ( edit, i think i'm gonna use that a lot from now on, i dunno if its been said before but if not quote it from me, lol, if its been said a lot, i blame the alcohol) the numbers don't lie
tlo86
Jul 24, 2005
3,914
Colorado
