Any of you guys change this gasket with the head attach to the block? Or, do I need to pull the head again, my mistake of not changing while the head was out. I appreciate you guys input in this matter.
			MmmBoost;903570 said:yeah, i did mine too... forgot to install the whole egr cooler assembly and didnt realize it until i started it up the first time.
gearwrench go-thru ratchet set ftmfwhttp://www.etoolcart.com/index.asp?PageAction=VIEWPROD&ProdID=4007
cuel;903394 said:Take the trans mount loose from the cross member, and jack the back of the trans. up. It'll give you a little more room between the head and firewall.
Doesn't pass here... there's no visual, but you won't pass the dyno check without it.Scot;903961 said:If I recall correctly. I removed the egr completely.... And it still passes inspection... How many people have their removed?
GrimJack;904166 said:Doesn't pass here... there's no visual, but you won't pass the dyno check without it.
