ECU
coleman_name
Oxford, AL
I just got a 1987 Supra. I was going to start with bolt-ons, but I was curious about the ECU for the car. Is the hp gain worth the $ or should I leave the chip alone?
koulee
497
I don't think there was ever an ecu upgrade - and even if there was, its probably expensive. Most people run fuel comps piggybacking or standalone when the time comes.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Best thing you could do with your money is first replace any hoses that look like they might fail, drain the coolant and put some Toyota red coolant in it, and check for any codes that have been stored and take care of that. Check the turbo for excessive shaft play. Then start with the exhaust system for the first modifications. This car can nickel and dime you to death if you start modding it before you make sure everything stock in the engine bay is in purfect working order. Also, if the radiator looks old it would be a good idea to replace it. The cooling system is very important for a 7m.
shaeff
Kurt is FTMFW x2!!!!
11
Around
there was the tech-tom ECU, and there was another that i can't remember at the moment.
-shaeff
shaeff
11
Around
jet performance ECU upgrade is a scam. read up on dr. jonez's sites.
the two i was thinking of were legit upgrades. not slap stickers on/in and go.
-shaeff
