ECU pig tail plug... What is it?
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
When I go to the shop tomorrow, I'll take pics of what i "think" the hac sensor is... Im just more confused now than I was... My main thing here is that this is something I DONT need for the AEM, because my AEM doesnt have that pigtail plug... And the only other plug it has is for the accesories and extra sensors...
zoppii
Pro Lurker
May 21, 2007
98
Palm Harbor
Red - Green comes from the Turbo Indicator (whatever that is, looks like and idiot light)
Violet comes from the Defogger relay
red - yellow comes from the headlight relay.
According to Toyota wiring diagram.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Thanks JJ... Will I need it for my AEM? Because, for some reason, I cant seem to find the extra plug that originally went to that pig tail...
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
I dunno much about the AEM Jake. All the defog and headlight inputs do is control idle speed through the stock ECU. The defog input compensates for the electrical load by keeping the idle speed near the same valve while the headlight input bumps it up a few hundred rpm. I dunno if that can be done through the AEM. As for the boost gage I'm assuming you'll be going aftermarket so no worries there.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Ok, talk about learning something new everyday... I always thought HAC stood for "Heat/Air Conditioning", probably because Im a construction guy, haha... Well, found the TSRM on line for the pre89 and found out the HAC is for High Altitude Compensation... http://www.supra.co.nz/87tsrm/EFI/efi121.htm Now if that pig tail is for the HAC sensor, then why do I already have a plug on my HAC sensor?
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
But I dont have an extra plug under my dash for that pig tail... Also, the AEM doesnt have a plug for that, so its just wierd... I dont think I've ever seen an ECU with the pig tail... Not that Ive seen ALOT of them, but...
