So I figured I mind as well make one of these builds since I'm pulling my motor for upgrades anyway.
Some background info on the car: I bought it this summer, I traded for my old white 87. The car to begin with was a project car, I took most of the summer putting it back together and finishing up the fabrication work.
Once I got the car running i then spent about 2 months replacing random shit that kept breaking
the car currently is equiped with:
1JZGTE:
Drewgo manifold
Drewgo Downpipe
T70 turbo
4'' exhuast
4" Muffler
4" Inlet
4" K&N filter
3'' aluminum charge Piping
24x12x3 FFIC
Tial Q BOV
COOLING:
Koyo oem radiator
Upper aluminum Coolant hose
2x 35mm couplers
2JZgte Fan clutch setup
2jzgte USDM waterpump
HEAD:
1ZZ coils
1ZZ coil brackets
BC 272 cams
BC springs retainers
HKS cam gears
HKS timing belt
Clear Timing cover
FUEL:
Precision 1200cc Injectors
Driftmotion Top feed rail
Dual Bosch 044 pump
10micron Inline bronze Filter
38' of PTFE fuel line
check valve
Flex fuel
ECU:
Proefi 128 ECU
Flex fuel E85
52mm CAN Gauge
Map sensor
Fuel sensor
Radiator Pressure
Exhuast Back Pressure
Oil Pressure
Flex fuel sensor
Wideband sensor
Traction Control
INTERIOR:
HKS Turbo timer
1GG tach
Gauge Pod pillar
TRD shift knob
Shifter and E-brake Boots
Sparco Sprint Seats
MKIII Wedge engineering Brackets
3'' 5-point harness
Suspension/Drivetrain:
R154 conversion
1-piece Aluminum Driveshaft
JZ bellhousing
JZ Flywheel
ACT XT Pressure plate
ACT 4-puck disc
ACT throw-out Bearing
SS Clutch line
Varrestones Wheels
18x10.5+30 Rear (295/40)
18x9.5 +30 front (255/40)
Tein Mono FLEX with EDFC coilovers
3.91 Rear end rebuilt Shimmed (2-Way)
Marlin crawler Thrust washer.
Poly Tranny mounts
Solid Motor mounts
Front Poly Bushings
Rear poly bushings
Brembo BBK 14.2'' Fronts
Brembo BBK 13.8'' Rears
F/R ST sway bars
F/R Stop tech pads
Shine S2 Front Lip
Shine S2 Air guide
Coatings:
Powder coat Valve covers
Ceramic coat Manifod
ceramic coat scroll
ceramic coat DP
ceramic coat wastegate
Polish Coolant
Polish upper coolant
Polish turbo
Polish Inlet
Polish Plenum
Polish Charge piping
MISC:
P/S SS line
Beech P/S ALum overflow
Beech Coolant overflow
I've been getting some other stuff together for the car, I'm pretty much finishing up on it and during the next few months I'll be installing everything.
Things I have to do:
Install ACT clutch kit
Make Proefi harness
Installed MPT70 turbo
Ill start posting up pics
Heres a taste:
---------- Post added at 12:38 PM ---------- Previous post was at 12:24 PM ----------
MAde my self some solid mounts:
Picking up the Proefi =D
Pulling tranny For Thrust washer and clutch kit:
Getting everything coated:
Mocking up 3'' IC piping:
---------- Post added at 12:42 PM ---------- Previous post was at 12:38 PM ----------
Suspension:
---------- Post added at 12:54 PM ---------- Previous post was at 12:42 PM ----------
Welding up custom made 3" exhaust with Megan tip:
---------- Post added at 12:58 PM ---------- Previous post was at 12:54 PM ----------
Priming and painting my engine bay:
1JZGTE:
Drewgo manifold
Drewgo Downpipe
T70 turbo
4'' exhuast
4" Muffler
4" Inlet
4" K&N filter
24x12x3 FFIC
Tial Q BOV
COOLING:
Koyo oem radiator
2x 35mm couplers
HEAD:
1ZZ coils
1ZZ coil brackets
BC 272 cams
HKS cam gears
HKS timing belt
Clear Timing cover
FUEL:
Dual Bosch 044 pump
check valve
Flex fuel
ECU:
Proefi 128 ECU
Flex fuel E85
52mm CAN Gauge
Map sensor
Fuel sensor
Radiator Pressure
Oil Pressure
Flex fuel sensor
Wideband sensor
Traction Control
INTERIOR:
HKS Turbo timer
1GG tach
Gauge Pod pillar
TRD shift knob
Sparco Sprint Seats
3'' 5-point harness
R154 conversion
JZ bellhousing
JZ Flywheel
ACT 4-puck disc
SS Clutch line
Varrestones Wheels
Poly Tranny mounts
Solid Motor mounts
Front Poly Bushings
Rear poly bushings
F/R ST sway bars
F/R Stop tech pads
Shine S2 Front Lip
Shine S2 Air guide
Coatings:
ceramic coat scroll
ceramic coat DP
Polish Coolant
Polish turbo
Polish Inlet
Polish Plenum
MISC:
P/S SS line
Make Proefi harness
Heres a taste:
Suspension:
