EBC Redstuff pads wearing correctly?
Did you slap pads?
Slides lubed?
I have ebc red stuff in the rears and i installed them with new rotors and they never looked like that.
I lube the part on the pad at each end that slides into the mounting bracket so everything is lubed and slides nice.
Edit: Looks like a metal to metal look on the outer edge.
honestabe;1529421 said:
Really dumb question, but should I be using the little spring thing on top of the pads?
Drivers side
The wear indicator for the pads is on back wards on the pad on the right in the pic.
Slap pads = replace pads with out resurfacing the rotors.
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
Shit, you're right guys. Talk about a stupid mistake. Oh well, atleast I didn't get much time driving them. Thanks guys, I appreciate it. Tomorrow I'll get the rotors turned, get new clips for the pads, and get new springs for the pads.
No prob.
But good luck with the rotors. Never tried as i use stock reg rotors but i have hear of problems resurfacing slotted rotors. Just something i have "heard" but as i recall you can chamfer the corners on the drilled part but mayeb you can do it on the slotted part as well. But usually they are replaced.
From what i have seen the holes are but the slots are not which they might need to be after cutting.
Imo i would just buy drilled and replace by needed but with slotted there really not chamfered the way they come.
