easyest way to get this beast back in...
whenmunkysfly
scratch that...going 2jz
Jun 26, 2006
746
United States
putting my engine back in today and was wondering since my tranny is still in the car would it be easyer to leave the pressure plate in the tranny like it is now and then bolt the flywheel to it when i get the egine in or take the pressureplate out and bolt it to the engine and then put the engine in.
EdgeSupra
506
New Jersey
It would probably be easier to take the pressure plate out of the transmission and then put it in as a whole unit.
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
I just did this on x-mas day and i put the pressure plate on the motor and aligned the clutch dish and i slid right together ,You do have to jack the tranny up a little but not a big deal.
SupraDreamPDR
Boost-a-holic!!
Feb 3, 2006
1,140
Springfield, OH.
GrimJack said:
Hate to point out the obvious, but... it will be easier to drain & disconnect the tranny, pull it out, bolt it onto the engine, and put it all back in at once.
+1 to that. sounds like more work, but in the end you will thank yourself.
whenmunkysfly
Jun 26, 2006
746
United States
well guys thanks for the help but i just put the pressure plate and the clutch on the tranny bolted the flywheel to the engine then popped the engine in the bay and got lucky cuz it popped right in. engines in and just need to pop on some intake stuff, attach some belts and put all the little things on.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
it really all depends on the mood im in, some times i yank the motor with out tranny, or tranny and motor together , or i'll just drop the tranny, either way it's not hard with extentions and an air ratchet,
toyota says to bolt the engines together first then bolt the pp and flywheel together, going this allows you do have the clutch fork pined and some how saving time i belive.
