Early 89 harness in a 86.5..................
DRIFTER WANNABE
DO WORK
Aug 15, 2008
75
southern oregon
I have searched and searched but didnt find my exact swap info..............
I recently picked up a 86.5 NA hardtop and am swapping in my 7mgte from my 89 targa turbo............\\
Will it all go together with a little effort or would it be wiser to pick up A pre 89 7mgte harness and ecu.....
I have heard there are benifits to the 89 ecu
Thanks for the input by the way i not keeping the abs not that it makes a difference
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
depends when the 89 was made. If its early it should be interchangeable. look at the plug color. If they are the same you're good.
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
I'm going to say no.
Everything I've ever seen or shown me (including information from Toyota) shows all 89 harnesses were the same, there was never a change made part way through the year. I'm sick of hearing that.
Jeff
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
DFW
You could always pull the dash and swap the body harness from your 89 to you 86.5. It's a time consuming pain in the ass though....I've done it.
DRIFTER WANNABE
DO WORK
Aug 15, 2008
75
southern oregon
Yeah its a grey plug harness so its not interchangeble with my 86 yellow plug
Im probably gonna swap the dash and body harness because the 86's wiring is looking a little on the corroded side............\\
Does this include wiring to the tails as well?
Are there any benefits to running a 89+ ecu or are they the same???????
thats gonna be the deal breaker.....
gtsfirefighter
Sep 26, 2006
2,966
DFW
The one thing I know of is the HAC is integrated into the ECU.
FYI, when you pull the body harness you might have to pull the blower motor housing.
DRIFTER WANNABE
DO WORK
Aug 15, 2008
75
southern oregon
Thanks for the responses i have decided not to pull the body harness
IM SELLIN MY 89 harness and ecu and gettn ones from a 88 or 87 is there abything i will have to interchange
Things that come to mind are
afm
Cps
coil packs etc.. Thanks DW
the 89 ecu has more hp and torque than pres's plus it ahs a stock redline of 6500rpm versus 90+ which is 6250.
all afm, coils, cps are interchangeable.
all 86.5's were non turbos so you need all the appropriate sensors for the gte.
DRIFTER WANNABE
DO WORK
Aug 15, 2008
75
southern oregon
I still have the 89 my turbo came out of so i got all the electronics i need
You say the 89 ecu has more hp n tq ?
I thought that 89 ons had +2 hp because a revised wastegate how does that ecu make more power??????????????????????
