e-manage Ultimate...Yay or nay?
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
sorry guys, i meant to ask how it compares to the maft pro.
drjonez said:
i'd go eman over the MAP ECU.....as it does more.
yup, you'll still need an AFM w/the eman.....which isn't a huge deal since the lex AFM maxes out around 600 rwhp....
Bishop92t
773
USA
www.ma70.com
http://www.mohdparts.com/emanage/ultimate/features/index.html
The new GEMU can remove the stock AFM, the question is how difficult will it be to set that map up. With the VPC/MAP ECU/MAFT you get the benefit of the conversion map already installed you just need to tweak it some. Still you can't compare the GEMU to the VPC/MAP ECU/MAFT, they do totally different things. GEMU is a fuel computer, while the other 3 were designed to remove the stock AFM. They all have limited fuel tuning capability, but only the GEMU/GEM are designed purely for tuning.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
hey guys thanks for all the help and good info you posted here. i made my decision. im goin with the e mange blue, and e 01. Thanks Adjuster.
bishop you said you have this set up also? just curious how hard the install is? how you like it on your car? and any other helpful info would be greatly appreciated. thanks
Mike
Bishop92t
773
USA
www.ma70.com
I've got the e-Manage blue and the Profec e-01, I've been running this setup for a long time and it's pretty nice. The biggest two drawbacks of this setup IMO is the lack of abilities to remove the AFM or reduce injector pulse width (it can only increase). There are no piggybacks on the market that can do all of these things except maybe the e-Manage ultimate. The problem with the ultimate is it doesn't interface with the Profec so you need to carry around a laptop to tune, or build a carputer.
Install was easy. Just slightly more difficult then a S-AFC/S-AFR install.
tkvtec
12
CT
I have the EMU and was going to install it this weekend, but got invited to a nice beach party. I spoke with a few people at Greddy about the setup, and yes as someone stated before, he told me to use the 3000GT as a baseline in the setup as they have a similar KV AFM engine size etc...
I also asked him about the conversion to remove the MAF and go pressure sensor. He said it would require a bit of datalogging and tuning, but yes it is doable. The A/F option port allows you to have the computer automatically tune to a preset A/F ratio which it reads from a Wideband sensor. I may be the first one to get it going, but we'll see. I have lots planned otherwise over the next week/weekend.
Also, I'd like to actually speak with some of the guys that got the EMB running on the 7M, so I can get some input, as it seems many of the settings in the support tool are the same. So, if you have it up and running on a 7M, PM me.
tkvtec
12
CT
I am positive that the EMU will interface with the Profec E01. They recommend doing the majority of the tuning on a laptop as it is quicker and easier, but the fine tuning and adjustments can easily be done with the E01. Also, the E01 can datalog I think 3 channels of data from the EMU. There is even a harness to plug into the EMU to let you use the E01's pressure sensor. I don't know why everyone is saying that you can't use the E01 with the EMU because I am almost positive I read tons about how you can. I will double check. I may be wrong, because I have been reading a ton and may have this confused.
Adjuster
I was looking through the EMU books on Mohad's site, and see nothing dealing with using the E-01 to program or use the EMU together.
If the Profec E-01 can interface with the EMU, and replace the AFM going to speed density using a IAT along with the Greddy pressure sensor I have already, that changes things considerably.
drjonez
the motor city
www.4cefed.com
that's news to me....you'll want to check w/greddy. i'm 95% sure that the E01 is NOT compatible w/the eman ultimate...
Bishop92t
773
USA
www.ma70.com
I talked to someone at GReddy about this and they said the two were not compatible. Supposedly even though the interfaces look similar (USB), one is actually serial and the other USB. You're probably thinking of the GEM/E-01 combo which does work perfectly.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
well whats a good WB you can sell to me? one that will do the job but wont break the bank? i thought i read that you could use a wide band on the Profec e01 but not the eman blue. maybe im wrong
Mike
drjonez said:
any WB you want.....there's no WB input for the eman or E01....
personally, i've used techedge and innvate stuff.
BTW- i sell innovate stuff....
