Dyno
91 mK3
Laaaaaaag
Aug 22, 2006
242
Hayward, Bay Area
so, after 7 months, i finally went and got tuned this past saturday. i have a
1 jz on stuck twins with the following mods
hks dwnpipe
3" piping
550 injectors
mkiv fuel pump
koyo aluminum radiator
boost controller
apexi safc
Here are the videos of some pulls
numbers were 270hp and 298ft torque on 17lbs of boost.
p.s. sorry bouh the repost thingie mah-jigar
SevenMKIII
No more Supra no more fun
Jan 13, 2007
474
Central IL
Sounds/looks like its pulling pretty strong! I don't know much about the 1JZ, but isn't 17psi a little out of the efficiency range for the stock twins? Or am I just stuck on the CT26's lack of breath :sarcasm:
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
WEAK!!!!
How in the hell did you get more TQ then HP???? You sure there isn't a 7M in there??
Freaking ricer :)
Looking goooooood man.
OneJoeZee
Retired Post Whore
aboard the Argama
17 is fine.
To the OP, as said in the other thread(not sure if you saw), those 550s are killing you I think. If you tuned them out enough to get that 11ish AFR, your timing is probably a little funky. You would have made more power on stock injectors. If you're planning on staying with stock twins for a while you might want to look into 440s instead. 550s are way more than you'd ever need with stock twins. 440s give you enough head room over stock injectors though.
I made 293 at 12-13 psi.
OneJoeZee;894363 said:
17 is fine.
To the OP, as said in the other thread(not sure if you saw), those 550s are killing you I think. If you tuned them out enough to get that 11ish AFR, your timing is probably a little funky. You would have made more power on stock injectors. If you're planning on staying with stock twins for a while you might want to look into 440s instead. 550s are way more than you'd ever need with stock twins. 440s give you enough head room over stock.
QFT
He speaketh the trufeth!
91 mK3
Laaaaaaag
Aug 22, 2006
242
Hayward, Bay Area
17 is fine.
thats hella good. what mods did you have?
BlackMKIII
Hardcore Lurker
Jan 6, 2007
2,134
Norman, Oklahoma
www.facebook.com
Dude. 550's are way too huge with what you have. If you're boosting a 17 PSI and AFR's are still dipping into 11's, you're way too rich. I'd hate to see it without the tuning.
I'm pretty sure that if I went and strapped down right now, I'd beat your numbers with ease, at only 13 PSI.
Jostar
AEM powered 1JZGTE!!!
May 21, 2007
746
Chicago
550s Are toooooo big for your set up, I made 310hp at 10 psi!! That was with an AEM ems though, Check your timing too & 17 psi is still safe in my opinion, I pushed them to 20 psi & made 422 hp, Again i have a AEM ems & that makes a huge difference.
Jostar
May 21, 2007
746
Chicago
Oh i just saw your vids...... You were doing 3rd gear pulls, I dyno mine in 4th gear, Anyone correct me if i'm wrong, Aren't we supposed to do pulls in 4th gear to match the 1to 1 gear ratio???
I've always dyno'd mine in third gear. The tuner says it's easier on the car. It's definately over quicker because fourth gear will wind out more. I made my 543 rwhp in third gear as well.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Uh Oh Jay, you may want to edit that post then. That's not your true HP because it wasn't a 1:1 ratio pull. ;)
You'd hate to get knocked out of the GTE powered club now, wouldn't you? :sarcasm:
I would hate to get kicked out, but I'd also rather not lie to them if I've did something wrong. I've always heard you'd dyno more in fourth gear. If this isn't true then I got some splainin to do to Duane and Miguel.
It won't matter once I get my 1.5jz done though. Ill have to be in the 2jz section anyways.
Chris, would I dyno more or less in third gear? Thanks
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
we tried to dyno my friends 1J in 3rd and 4th, his car definitely like 4th better
he made 340whp going up to redline in 3rd (mustang dyno)
in 4th, he hit speed cut at 6200 and made 377whp
but like its been said, those 550s are probably hurting you more than helping
Syris
Need Rust Repair
Aug 24, 2005
687
Bryan, OH /Lima, OH
You Don't dyno in 3rd gear for its multiplied, You have to dyno in 4th to get true results for 1:1 ratio.
Jay your numbers are off then if you made that much in 3rd, they will end up being lower....
For example if you made 200 hp in 4th and your 2nd gear had a ratio of 2:1 you would get the results of 400 hp.
Jostar
May 21, 2007
746
Chicago
upgradedsupra;895593 said:
4th gear is a 1 to 1 ratio in the MKIII.
Oh,and no worries hillbillie, I got your back.
Lol.. i thought people knew about doing dyno pulls on 4th gear in the MKIII, In the MKIV it's 5th gear!:aigo:
Will I be tar'd and feathered, draw'd and quartered, lethally injected, or hung until dead?
I shall take my own life for trying to deceive you good people. So long cruel world.........::hang::
Markiii
Cambridgeshire
which diff is this with? I've got a 1G with a 7MGTE diff so is 4th still 1:1 with this set up?
I'm planning a dyno soon so this will be useful to know
Cheers
