Dyno results: March 8, 2008 (MK3Brent GT4088)
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Finally got the chance to get the car on the dyno and try out my new goodies.
I'm maxing out (in my opinion) the capabilities of my fuel injectors, but yielded me 564hp & 510tq.
The engine was pulling so hard to redline, that you can see in the video the motor is torquing out of the engine bay. (Time for new mounts.)
I started tuning AFR's at around 19psi of boost and by the end of the dyno I was boosting 20-21psi.
I don't care what some say, the GT4088 is an amazing turbo and I would recommend it to anyone.
Pictures from today:
http://img.photobucket.com/albums/v635/BrentlyandMeghan/DSCN1478.jpg (Full res.)
http://img.photobucket.com/albums/v635/BrentlyandMeghan/DSCN1480.jpg
(Full res.)
http://img.photobucket.com/albums/v635/BrentlyandMeghan/DSCN1484.jpg
(Full res.)
http://img.photobucket.com/albums/v635/BrentlyandMeghan/DSCN1485.jpg
(Full res.)
VIDEO:
http://www.youtube.com/watch?v=iKds3hbVNTQ
-Brent A.
Looks like to me you're gonna have a traction problem ;)
Curves are nice & steep between 4-5K RPM...looks like a bit of "chop" in the lines at peak RPM though. Ignition?
When does the 4088 start to spool?
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
500+ on 19psi? i didn't think it would flow that much, i thought something bigger would be needed for that. what are your other mods?
I would have guessed a 67mm turbo would be needed for that, Sweet numbers though, maybe will change my turbo plans.
tissimo
Stock is boring :(
Melbourne, FL
what size backhousing? thats a very short powerband, but nice numbers
my 1jz with a 67mm spooled faster :biglaugh:
MK3Brent
Very expensive....
Aug 1, 2005
2,878
.81 I believe rear housing, it's been some time.
jdub: In real load, it'll spool 1bar by 4300rpms. Ignition was also a concern as to why I stopped early on the dyno. I have a new set of NGK's going in, as the ones in now are .025"
Nose: Boost that got me 500+ was between 20 and 21psi. The engine is a fresh build with .020 over JE's, Crower i-beams, and fresh stock spec head.
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
Nice numbers brent. Time for a new FFIM with bigger TB and bigger IC pipes! wink wink! I bet that is where the real power is coming from is that FFIM!! lol
Looks real good tho!
Thanks,
Seth
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Thanks,
Seth
Yeah, I'll know where to find you!
For those who don't know, Seth built the FFIM on my car. (Grade A work!)
I'm leaving the piping at 2.5" and stock TB and do 600hp+, there's no doubt in my mind I can do 600+ on this setup with just adding 10 more psi and 680's and A1000.
I'll post when I do.
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
Haha that is insane!
Seriously your setup would do 600rwhp right now with just a 3" TB and 3" IC pipes!
Keep up the work. I will have to check it out sometime. Just picked up a 92' today!
Thanks,
Seth
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Thanks for the compliments!
hott: Thanks. I can't wait to get the 680's in and the A1000.
I've decided to get a fuel cell from summit that's already sumped and do the a1000 or equivalent external pump.
We should all get together soon for a meet in VA or something.
-Brent
bmoss85
Permanently Banned Scammer
Apr 14, 2007
1,026
clemmons, nc
good work, where did you dyno at?
edit: nevermind i didnt see turbo tune in the video at first.
