DSM injectors
Sorry if this has been discussed before, but I didn't get far when doing a little research.
Are DSM injectors able to be used for the 7M or are they not interchangeable? I came across a cheap set of 550s listed for a dsm so I thought I'd check to see if they'd be worth looking into.
Devin LeBlanc
1,830
Las Vegas NV.
Im pretty sure the EVO injectors drop right in, other than the clips being different, all you would need is pigtails to splice into your harness.. I think the Evo injectors are 560CC's
Possible yes, but I want to see if anyone has had prior experience and knows for sure before I go off and buy something I can't use. I seem to recall reading that evo ones would work in DSMs but that a DSM injector couldn't be used in an evo rail.. anyone want to confirm this further?
