Driftmotion Stinger 4244 plug and pray help
Mk3Les
I’m just wondering if anyone has used one of these, I got mine a couple of years ago but Ive only just gotten around to fitting it. From what I understand it was a pretty strait forward exercise, unplug factory ecu plug in the stinger load a base map (I’m using a 1jz base map) run a wire to an air temp sensor and a vac line back to the stinger, sounds simple. Anyway I can get the motor to turn over but not run it feels like its not getting spark, the software shows a 1% injector duty cycle when cranking it over so I’m guessing its getting fuel (although I could be wrong). Any help would be great I really don’t want to start pulling things apart until I’m sure that it’s not something simple that I’ve missed.
Also if anyone has a 7mgte base map that they could send me that would be great.
