does it stick?
boostadikt
Freeway Foreplay
May 11, 2006
678
c-ville, Utah
uhmmmm okay so i just have a simple question, and i want you to think about this a little dont just say yes or no.... and i don't really want to get into why im asking right now, okay sooooo will jb weld bond to brass? say filling a brass fitting with it, then putting 60 lbs pressure on it.. will it hold or get pushed out? if you put jb weld on steel you can usually just scrape it off. so what about brass?
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
maybe it will hold, but first, whatever surface you are filling it with, make sure it is rough and has surface for the jb weld to adhere too. You can take a rouch sand paper and go at it beefore filling with jB weld. The bonding will be stronger
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
Yellow 13 said:
Ive never had good experiences with JB weld. So I wouldnt trust it for anything on my car, especially engine wise.
jb weld SUCKS ASS. over the years, i have used it maybe 15 times, each time hoping i would get better results than the last. and each time, i followed all instructions on the package, prepped the surface properly and mixed/cured properly too.
each time it flakes off with light pressure from my fingernail. :3d_frown: jb weld is worthless, and the testimonies on the back are complete BullShit. im so glad i got an arc welder.
noredline
Yeah, I'd stands on that.
Sep 26, 2006
94
Chandler, AZ
agreed, whatever your attaching it to it must have a plyable surface.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i used it befor worked great heat is the biggest thing when useing jab weld and a proper mix
but you can only se it on so many thigns
Clip
Oct 16, 2005
2,738
9
Virginia
i just hate the stuff. maybe virginia's jb weld is different than alabama's.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
if its a safety part...No Frigging way!
if its something that would make the car inoperable if it failed, No frigging way.
if it was on a part that I could live without for a day (say like a cruise control actuator) I say give it a shot.
however if your just dealing with brass why not get some plumbers solder and a propane torch and "fill it and drill it" ?
