do they still make the Do-Luck Rear Cross Brace
suprajjang
Supra Enthusiast
VA
last time i talked to dusty at mvp i think he said he can get them but its going to take 6+ weeks or something along that line
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
It's very thick and heavy, and I feel it helped with targa flex a bit. It bolted to the seat belt bolt, but I had to tap another bolt into the rocker panel to keep it in place. I then cranked the center nut and put loads of pressure on the rockers. I also painted it black.
KeithH
Portland, OR
If you had to tap a hole then you have a generic one. Toyota put a perf'd hole in the carpet and a threaded nut was welded to the body in the perfect location for the right bar.
Larry Anderson once commented that it was an 80% improvement on the chassis flex without the roof. I wouldn't call it useless.
