Do I need anything else other then springs and struts?
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
I'm going to buy some springs and struts now. Beacue I found one of the rims I was going to buy used to have a crack in it, so I ended up no getting them. I was thinking of a kyb gt2 and eibach set up. Do I need anything else besides the spring and struts? If this question was asked many times before I'm sorry. I looked for an answer and could not find it.
Thanks
Boris
hot dayam mk3
149
umm have dust boots and check your bumper stops on the struts too. i ordered kyb dust boots with bump stops included they cost about $20 a peice.
koulee
497
Well go all out and get an upgraded front sway bar and adjustable front endlinks.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
BorHor said:
Are endlinks also worth that extra money?
It depends on the fact if you will be making changes to the handling/stiffness of the swaybars quite often. For daily driving and occasional spirited ones, I don't think its needed, but that is "MY" opinion. Someone else may think otherwise.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
SWAYBARS FTW.
Just hold a stock supra swaybar in your hands. You'll understand why an upgraded swaybar is imperative.
koulee
497
The majority of the swaybars for the front are non-adjustable. But just look at those wimpy stockers in there dude.
MDC sells them for 125 a pair, and its like the only place I know of that sells them.
Well actually he has them made and then sells them.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Aiight I'm mostly going to do dd then have fun in the mountian once in a while. So front sways are a must? what about rears?
koulee
497
If you upgrade the rears you better get the mounting tabs reinforced or you will break something. Since the Supra was meant to handle I would just get a stiff front end and leave the rear end stock.
hot dayam mk3
149
i believe a-1 actually makes the replacent arms with stronger links for $175 which i think is a steel. might as well go all out ftw!
