DIY Boost Leak Tester
2jzmk3
Guest
Boost Leak Theory
Boost Leaks, while easy to diagnose and fix, are often over-looked by turbo car owners for one reason or another. Whether they are overlooked because of laziness or ignorance, they rob power from your turbo car and cause it to perform at much less than its potential. In this article we will discuss not only why and how boost leaks could be holding your car back but also how to make and use your own boost leak tester.
Any air leaking out of the plumbing system from the compressor side of the turbo to where the intake manifold meets the head is considered a boost leak. In a vaccume condition like at idle, air would be being sucked in through a boost leak, and in a boosted condition like full throttle air would be blowing out of a boost leak.
Most turbo cars use an air flow sensor to meter air as it is brought into the turbo. As air passes through the air flow meter, it is counted and the ecu assigns a certain amount of fuel for that amount of air. Lets consider a hypothetical situation of a particular boost leak. Air passes through the air flow sensor, is measured and counted, and the ecu assigns a certain amount of fuel for that particular amount of air. As the air passes through the turbo and begins its path to the head, some of it escapes through a boost leak, (in this hypothetical situation we will use a bad throttle body gasket as an example of a boost leak). The air escaping through the leak was measured and considered in calculations when the ecu assigned the correct amount of fuel for the mixture, but the ecu does not know that some of the air is leaking out through the damaged gasket, and does not adjust for it. In this situation less air will actually be reaching the engine than was metered, and the fuel will remain unchanged, throwing off the tune and causing a rich condition. This rich condition will cause your car to run at less than its potential.
Not only will this rich condition cause your car to run at less than its potential, you may notice that your car has trouble holding boost through the gears at wide open throttle. Throwing off your tune, and not being able to hold boost is enough to make you lose a great deal of power that your car should be making.
Boost Leaks arent only harmfull to cars with airflow meters though. Any turbo car could potentially be harmed from boost leaks. Boost leaks make the turbo work harder to do the same amount of work, and could lead to a turbo failure because of it. To demonstrate this, imagine building pressure in a baloon by blowing air into it with your mouth. Then make a tiny hole in the baloon and try to blow it up again. You will notice you are doing more work than you did the first time to inflate the baloon to the same size. Hopefully this section has motivated you enough to check your car for boost leaks. Now on to how you can make a Boost Leak Tester with parts readily available at your local hardware store.
Parts Required
3" to 2" Coupler 2" PVC Cap Air Line Fitting Teflon Tape
Parts Required:
1 (3" to 2") Rubber Coupler w/ Clamps
1 (2") PVC Cap
1 (1/4") Air Hose Fitting
Teflon Tape
Boost Leak Tester Assembly
Assembly Notes: This boost leak tester was designed to fit over a 3inch turbo inlet. If your turbo inlet size is different than 3", you will have to purchase a different coupler that will fit over your turbo inlet, and possibly a different PVC Cap depending on what size the opposite side of the coupler is. The assembly process is the same though, as long as one side of the coupler can fit over your turbo inlet, and the other side ends up with the PVC Cap in it.
Step 1:
Drill a hole in the top of the 2" PVC Cap.
Step 2:
Wrap 1/4" Air Hose Fitting Threads in Teflon Tape.
Step 3:
Screw 1/4" Air Hose Fitting into 2" PVC Cap.
Step 4:
Place 2" PVC Cap in the 2" side of the coupler and tighten the clamp.
Pressure Regulation Note: This boost leak tester was designed to be used with an air compressor that has a built in pressure regulator. If your compressor is not able to control the amount of pressure it puts out. You can purchase an in-line pressure control regulator and gauge from the air compressor section at the hardware store, and set the target pressure right at the tester.
Boost Leak Test Procedure
This section will describe to you in detail, how to perform a boost leak test on your single turbo setup. If you are using a twin turbo setup, an alternate method will be described after this one.
Single Turbo Setups:
Slip BoostLeak Tester over the compressor inlet of your turbo.
Tighten Clamp
Set pressure on air compressor to desired amount of boost. (It would be a good idea to set the pressure on the air compressor to the amount of boost you would like to be running in the car. For example if you are planning to run 30psi, set the compressor to at least 30psi.)
Attach the air hose from the compressor to the quick disconnect fitting on the boost leak tester
At this point you can take the time to listen for air leaking out of the system. The system will be pressurized so any air leaking out should be easily audible. If you are having trouble finding a leak, feel around the general area and feel for air on your hand.
Once you've located the leak, now go through and fix it
Twin Turbo Setups:
If you are using a twin turbo setup, the procedure and assembly change a little bit. Instead of using a boost leak tester like we have described, you will make two smaller boost leak testers that do not have fittings tapped into them. They will essentially act as plugs to block off the intake inlets on each compressor housing. Then you will use a small barb fitting on the air blower attachment for the air compressor to feed boost into a vacuum line. Once both turbos are blocked off, you can unplug a vaccum line from the blow off valve, or wastegate, and feed air into the system through that line.
Testing Tips:
If you are using a bleeder type boost controller, air will leak from it durring the boost leak test. Either take it off and replace it with a hose or try holding your finger over the bleeder hole to keep it quiet so you can hear actual leaks.
When performing a boost leak test, if the system is pressurized and you arent hearing any leaks, try opening the throttle body.
Have someone sitting inside the car keeping an eye on the car's boost gauge to see if it is reading the full amount of pressure being fed in through the compressor. This will give you an idea of if there are any leaks you might be missing.
Write up Courtesy of
www.BoostCreeps.com
Steven
23
Toronto
Joel W. said:
This could be stickied or moved to tech tips?
:dunno: But I like it..:)
Here is another page..
http://www.vfaq.com/mods/ICtester.html
Maybe I'm missing something here, but I can't see how to keep air from flowing through the head and out the exhaust. Is there zero intake/exhaust valve overlap on a 7MGTE?
If throttle valve is closed to prevent blow-through the head, then you don't get to test for leaks at your intake manifold gasket....
MA70Snowman
374
San Diego
maybe i missed something, but I bought the 3" - 2" adapter and when i went to put it over the compressor housing. it was to big. tried it on 2 supras. Are we sure about that fit?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
What part of...."this boost leak tester was designed to fit over a 3inch turbo inlet. If your turbo inlet size is different than 3" you will have to purchase a different coupler that will fit over your turbo"....didn't you understand? Iirc the CT-26 is 2.75"
MA70Snowman
374
San Diego
1) I have a habit of skimming for the actual info, especially when pouring over post after posts on these forums
2) i figured being a general write up, it would've been geared towards the stock set-up on the 7ms.
and 2.75 sounds much better thank you much. I'll try that this time.
Suprra girl - "but i would probly just end it at the 3000 pipe for testing as previously mentioned the head poses a small problem with leakage
but i was thinking of making these kits here... GREAT IDEA! hehe"
capping after the 3k pipe is almost a must as listening for a leak you hear alot of air in the engine itself, instead of buying 1 cap just buy 2 and cap the end of the 3k pipe. and I also thought about making pre-made kits myself. but it just wouldn't be marketable tools required for this job are a small drill/dremel and a flat head screwdriver (for tightening the clamps) anyone can run to lowes and make this for next to nothing. now maybe if you included the regulator built on the end of the cap and a schrader (sp) valve so anyone w/ a tire pump could do it, then you might be onto something. but that regulator drives the price up pretty nice.
Piratetip
Far From Maddening Crowds
1,152
52
MKE, WI
This won't work.
The only way you can test the IC system is to completely block off the intake into the TB.
You will get leaks from the Throttle Plate, ISC valve, then on through the intake, valves (there is valve overlap, Steven already pointed this out), combustion chamber, exhaust, out the tail.
You should point this out in your instructions.
Edit: MA70Snowman has a good solution.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
if you block it off at the end of the 3000 pipe, then how would you test if you have a boost leak after the 3000 pipe, such as a TB gasket or the grommets that go on the injectors on the manifold?
so the ct26 inlet is definetly 2.75 right?
Piratetip
1,152
52
MKE, WI
If you take out the cams in the engine and let all the valves fully seat then you can test the TB gasket and injector grommets. Otherwise you will have air blowing through the engine.
Or if you are lucky enough to find a position on the crankshaft where all the valves are closed (or there is no overlap) it may work. But I don't know of such a position. Anyone? IJ?
Boost Lee
Bee Doo Bee Doo Bee Doo
2,750
Indianapolis, IN
If you have any concerns of it being your throttle body gasket, it's a 5 minute job to pop it off, inspect the gasket and use your good judgement then and there whether it needs replaced or tightened at that point.
And yes...sealing off whatever pipe you have going into your throttle body will do the job. Doing otherwise, as stated several times already, will just leak out of MULTIPLE things. Doing it as said in the original post will still work 9 times out of 10 if it's an obvious boost leak, otherwise, It won't be much worth of anything as far as accuracy goes.
-Jeff
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Hoping this doesn't come back to bite me on the ass for saying this with such confidence but:
There is no position where all valves are fully seated.
I'd give it a 0.01% chance that I'm wrong ;)
bosco659
Toyota nut
Oct 11, 2005
Canada
Tested my set up and found quite a few leaks, the largest was from the BOV mounting flange. I tested up to the 3000 pipe only as there was too much air leakage at the throttle body etc. How did I cap off the end of the intercooler pipe before the 3000 pipe?? I stuck a beer bottle in the end of the silicone connector and it fit perfrectly :)
Only problem I found was that the 2" to 3" rubber adaptor wouldn't seal 100%around the intake for my CT26. The CT26 inlet is 2.75" and the ID of the rubber adaptor is about 3.5". I couldn't get the clamp tight enough to get a perfect seal and it popped off a couple of times.
Great idea and cost effective way of checking for leaks. Higly recommended procedure. I thought all of my clamps were tight but found many small leaks. Liked it so much that I bought a 2.75" silicone coupler and will make a test unit that will fit perfectly.
BTW, t-bolt clamps are highly recommended!
Thanks for the tip!
jnybbad
61
vacaville, ca
I know this is very old but came across it and thought, why not plug the exhaust and pressurize the whole system to check for leaks? You coul even manually spin the engine while pressurized to check eack cylinder..
Aug 24, 2009
126
Nirvana
You'll blow the seals out of your engine (front main, rear main, etc..). Ask me how I know xD
Janch
271
Riga
i've been looking for a long time how to do boost leak test on 7MGTE and information that you have to block off after 3000pipe is VERY useful. thanks guys.
