dipstick blowing out??
skez
12
mackay qld
i have a cressida with a 7mgte in it and the dipstick is continualy blowing out, i have checked all the lines for kinks etc and cant see anything wrong,do these have a pcv valve because i cant find one? wat should i do its really annoying
check your pcv system. is it hooked up like stock? your lucky your not blowing out your mains. there is no pcv valve. jcheck to make sure the orifice in the tb port is clean. it gets smaller inside there and can clog up.
Bootymeat
51
Bev Hills 90210
skez;1473835 said:
does any one have pics to wat parts need cleaning apart from the throttle body
You have 2 pipes that lead from the rear of the valve covers to the throttle body. Take out that pipe, spray some carb cleaner in there and get all that gunk out. Where the pipe goes into the TB is what you should clean.
But I'm sure cleaning the whole throttle body wouldn't hurt.
dumbo
1,913
Albera, Too Far North
Being turbo I would make sure the line from the valve covers to the pre turbo is good. Once you get into boost air is going to be coming out of the TB neways.
89supra7mgte
797
colorado
how does the car run? does it start fairly easy on a cold engine? you said there is no smoke right? everytime i have ran into bad rings on any engine it would smoke.
skez
12
mackay qld
yeh the lines look all good an yeh the car runs normally cant notice any difference except for when i give it to much the dipstick blows out
89supra7mgte
797
colorado
sounds to me like you might have a line plugged in the pcv system. some how or another seems like you are boosting the crankcase as well as the engine. make sure the ports under the valve covers are clean as well. some have baffles, if plugged your pcv system is not working.
skez
12
mackay qld
yeh ill pull it apart either today or tomoro and yeh if i drive it easy and dont boost it its fine but if i put the foot down in a high gear it always blows out and im not sure wat u mean about ports under the valve cover but ill have a look and i really just want to get rid of all the shit i dont need like pcv or anything to do with emissions etc..
teebone
101
Corvallis Oregon
I went thru the same exact thing. PCV was working properly, new rebuild and rings were seated, etc. I bought a new dip stick from Toyota..... It stopped popping out, just FYI
uhh you need the pcv system. its necessary. pcv stands for positive crank case ventilation. meaning that if you cap those ports on the valve covers you will blow out your mains and blow your engine. this is no way around it on any engine. if you remove egr and such you should tune for it.(there will be guys that will tell you your fine with out it but the FACTS are that you need it unless running a standalone.)
