Differences between the 88 and 90 years of the 7MGTE Block and Crankshaft?
927mgtepat
653
Brighton, MI
Hello guys, I got a couple of extra engines laying around and am trying to find out which are the older style 7MGTE and the newer ones. I have heard that the 7MGTE cranks have extra counter weights. What are the differences on the blocks? Some of the blocks that I have, have a stronger looking cradle and extra supports on the out side of the block, is this the 90 style?
Pic #1 and #3 are a 92 block #2 and #4 are an 87
92 block is at least 2mm thicker everywhere so much better and don't seem to suffer the deck cracks like the early blocks.
Top pic 7M bottom 6M
NA's got the heavy block before GTE's did (Group A race motors are cherry picked NA blocks)
There's a lot of confusion as to when all the changes happened so it's possible.
The above 87 block has 18K miles on it and is cracked in a few places.
Only problem/Issue with a late block is a lot of core shift at the foundry so before trying a monster overbore I'd have it Sonic checked to make sure there's enough wall thickness (but you'd do that anyway)
turbodriz
mk3 onwer
Feb 25, 2006
471
newyork....N.c
I am looking for one of the newer style blocks. Are use saying that nobody knows what year they actually came out. What is the difference betweem the na and gte block?
