diff search
taka21
363
washington dc
CT26smoker;1670088 said:
The MkIII is an 8".
So what are you asking ?
mk3 supras have a 7.5" rear not an 8"
and thus no one makes a spool for our rear as yet if it was an 8" there are several to choose from
---------- Post added at 12:41 AM ---------- Previous post was at 12:39 AM ----------
bioskyline;1670179 said:
looking to change your gear ratio?
yes but more importantly i want a full locking spool but no one makes one for our 7.5 rear
No you cant swap a ford into our pumpkin. You want another diff you swap it in which means straight custom.
Jawsgear makes diff with a 3.55 gear ratio. Thats about it. you can get kazz trd and some others. No real need for huge after market on that since stock is prolly stronger than r154.
bioskyline
1,236
powell river bc
i looked at my axle tag on my supra, which is G285. according to my toyota axle sheet, the G series axles are 8 inch.
the mk2 supra has the F series diff, which is 7.5. the mk3 has the 8 inch diff.
http://www.toysport.com/technical information/toyota differentials identifications.htm
the v6 4runners use the same carrier, pics and info on the link http://www.4x4wire.com/toyota/tech/supra_lsd/
taka21
363
washington dc
so then this piece should work just fine then right ?
http://www.marlincrawler.com/differential/locker/spool-locker/spool-hilux/spool-8-v6
te72
Classifieds Moderator
6,622
9
WHYoming
You still have that thing IJ? Figured one of the drag guys would have picked that up by now...
