I would like to get you guys input on my diff. My car is an 87 na that i went turbo but i still have the na diff i have a choice of getting a turbo diff would i see a difference in power or better gearing?
CzA;1401836 said:the first thing i would want to do is check to see if your diff has lsd.
“'86.5-'92 MA70 N/A MKIIIs without Sport Package have a 4.30, open differential. “
“'86.5-'92 MA70 N/A MKIIIs with Sport Package (TEMS & headlight washers on '86.5 - '88 : TEMS & PPS on '89-'92) have a 4.30, clutch-pack LSD differential.”
The 4.3 with LSD is not an easy find (at least for me it isn’t.)
The advantages of having the 4.3 are that you accelerate quicker through gears making it an ideal setup for the ¼ mile. The downside is that you do run out of gears quicker and compromise your top end speed ( i have brought mine to the 240 km/hr range). Also your rpm vs speed range is altered , and you will now be doing more work at 100 KM/h vs one with a stock turbo diff which is approx 23-2500 rpm, which means fuel consumption is not as good for highway driving. you will also burn more oil, as you do more work rpm wise too.
I have the 4.3 lsd in my car, i don’t see myself going back to the 3.73 (89+ turbo diff). me the pros out weigh the cons. 87-88 turbos had 3.91 i believe.
Princesupratn;1402174 said:From what i'm reading i think should stick with the diff i already have. As the top end part i guess an easy fix would be more power huh problem solve:naughty:
