Did I fry my my electronics?
JohnRardin
JDM 7MGTE
Apr 4, 2006
110
Radford, VA
I noticed the smell of gasoline and saw a leak near one of my injectors so I took off the throttle body, 3000 pipe, the fuel rail, and everything in the way of it. While doing this I accidentally let a wrench hit the alternator and it sparked like crazy. After replacing a blown O-ring in one of my injectors, I put everything all back together and tried to start it. Nothing. No starter click at all. The only thing I have to go on is a clicking noise in the main fuse box when turning the key from OFF to ACC.
None of the fuses are blown so the only thing I can think is I either fried a wire, circuit, or the main fuse or the Head fuse. All I know to do is replace the main and head fuses. Has anything similar happened to anyone else? What other possible problems are there?
Justin
Speakers?
Spokane, Wa
Every. Single. One.
No, just kidding.
Chances are you blew the ALT fuseable link.
When Removing it, before you break anything, unbolt the two bolts holding it in on the bottom of the fuse box ;)
isnms
United States of America
Oklahoma
i80.photobucket.com
Also check the fusible link and the others
JohnRardin
JDM 7MGTE
Apr 4, 2006
110
Radford, VA
Where exactly is the fusable link between the headlight and fusebox? I have it all apart and I can't seem to find it.
[/QUOTE]
isnms
Oklahoma
i80.photobucket.com
It attaches to the positive terminal and is likely covered with black heat shrink. Follow the wire from the positive terminal that connects to a white wire under the fuse box. That one is it.
edit: white not white/black
Z'mnypit
116
Springville, AL
This is going to be your problem. Did the same thing the other day lol!
