Diagram on How to route PVC lines correctly with a Catch Can?
Angry7M
Formerly redmaro
Sep 6, 2007
733
AZ
Anyone have a dagram on how to hook up the PVC lines correctly with a Catch Can? Or is the stock PVC hose routing good enough?
A diagram will be best, I also searced and only found one major thread, but no diagrams. Thanks
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
After reading the above-mentioned thread, I just finished doing mine:
The pcv can itself is not in the engine compartment, but rather- I mounted it under the driver's headlight. (A), because i wanted it in a cool area, (B), I was running out of engine compartment room. The valve cover hose goes to the inner fender by the clutch resevoir, and out between the fender and inner fender splash guard, so its hidden. The throttle body line goes down by the driver's frame rail, and along the AC lines, and pops up in between the radiator and the intercooler, to tee into the line that goes to the intake. The intake line runs along the top of the bumper support.
Here's the routing:
supraguy@aol
Well-Known Member
Dec 30, 2005
4,242
Atlanta
Thanks. Yeah I'd left mine on a shelf in the garage for years, because I was too lazy to route it, and didn't know the proper way.
Then I read this thread the other day, as well as the thread in the above link, and finally got motivated to do it.
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,250
Charleston, SC
So is this indeed the correct way to run PCV in a single catch can system? I need to install mine one of these days. If I were to incorporate one-way check valves into this setup; there would be one coming off the intake pipe flowing towards the CC, and one coming out of the FFIM flowing away from the CC. Correct?
stolensupra
Gotta spray to play!
Jan 2, 2010
150
NORTH CAROLINA- Greensboro
Yea I've had a catch can originally for my celica in my closet for like 4 years before i bought my supra and still haven't installed it. Laziness.
