okay, first off the whole ignition system is new, and the wiring is good. My problem is that when under boost and then go wot it cuts out bad. Mods are single 67mm turbo, precision 780cc injectors, emanange ultimate, profec b boost controller, ect. The car drives fine other than this problem, and if not wot, you can go to redline with no problems. Boost is set at 15lbs, plugs are gapped at .32(tried .26 with same result). All the coils are new, igniter is new, checked coil and injector wiring. If anyone has any ideas or suggestions would be greatly appreciated. thanks
