cutout when reving
86.5supraturbo
BOOST FREAK
Nov 27, 2008
31
Dixon, Illinois, United States
got a ? when i rev my car up it cuts out at about 4000 rpm's what can i do to resolve this? Also when i push both the window switches up my rpms come on i let off n the rpms drop to zero n dont work. They also kick up sometimes when i turn on the blinker? whats goin on here? Knock sensor on a brand new rebuilt motor with new sensors, still throws a code even after unpluggin the battery to reset it. LMK if anyone knows about ANYTHING in here PM me plz
86.5supraturbo
BOOST FREAK
Nov 27, 2008
31
the code for the knock sensor is coming up u drive normal in 1st gear then in second or whatever gear and boost it it cuts out and sounds like ur sprayin air n ur not boosting romp out every gear n get no boost or pull feels stock the knock sensors are new
gaboonviper85
3,236
Northeast Philly
WTF did you just say?
Seriously man....
shaeff
Kurt is FTMFW x2!!!!
11
Around
Translation:
The only code I'm getting is Code 52, as the TSRM states it's for the knock sensor circuit. If you drive normal in first gear, then in second, or try to boost in any gear, it will cut out and sounds like a woosh of air, and I'm not building any boost. Even if I romp on it in every gear, I get no boost, no pull. It feels stock. The knock sensors are new.
supra90turbo
shaeff is FTMFW!
MA, 01440
haha shaeff!
Sounds to me like it's a boost leak. I've held off chiming in here, but it seems like it runs like a car with a bad or unplugged AFM.
Have you checked the IC pipes? Make sure the pipes didn't have any cracks in them. (I know mine were rock solid and didn't resemble rubber any longer)
I don't know what to do if someone isn't willing to help their own cause!
