Cut springs?
SuprAng
Garage Queen VV
Apr 4, 2005
112
Toronto, ON
why dont you guys post info to your assumptions?
Camber problems - Any lowering spring will give you increased neg camber.
Uneven tire wear - look above.
Unsafe - Not really. Unless you are talking about the spring not seating properly and coming off the mount, which can happen but usually because you cut them wrong.
Blown struts- AGAIN, any lowering spring will blow old shitty struts and even new oem ones, because their pistons arent meant to travel that low.
Spring rates do increase and becuase they are linear, matched up with a nice strut you can get good performance out of them.
Do what you want but those are the facts as far as i know.
Ang
89mkthree
supies ignore irish luck!
Apr 12, 2005
138
near chi town
cutting springs can mess with the integrity of said springs. i had a friend that cut his and they ended up cracking. and before anybody says they were probobly old springs, they were only 1000 miles old.
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
They are linear springs, pretty much everything negative said in this thread is incorrect, if they were progressive coils then ok, but they aren't. Cut them correctly (so they still seat on the perch correctly) and you are fine. Do not cut more than one full coil off, you will regret it as it will be much to low. I had cut mine so that the coil lined up exactly in the same spot, just one coil lower, and the car is low (scrapes on driveways and speed bumps, good thing the stock front lip is so durable, if you have a fibreglass lip, kiss it good bye). Stock size rims/tire combo and the fronts have next to no clearance before rubbing the plastic liners. It is a very agressive stance though, and will therefore require a much stiffer shock.
Get them heated if you want even more improved handling, cut + heated stock coil springs handle better than eibachs.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
we cut off my springs and it handled fine it rode a little rough. but it did give it a mean looking stance. the only thing i didnt like was when you were racing with the rearend not lowered any it tends to want to spin more. i guess cause of the shift in weight.
Blksupra1jzed
153
Raleigh, NC
Yeah, I am definately not looking to cut more than a full coil off, also as stated I will be getting eibachs in the next month or so and wanted to see if this would be something worth doing to hold me over....
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
suprasport91 said:
Cutting your springs is the way to do it, its how all the hondas do it, and believe me they know what they are doing!!
I bet you I can find SEVERAL street "hondas" that can hand you yours ass in every form of racing, don't be so ignorant. :icon_bigg
suprasport91
GO BRUINS!!!
Sep 27, 2005
336
Seattle, Wa
im sure they can, but there are always possibilities for things to happen, i just dont understad what a thousand dollars is gonna hurt when your life is at stake, and about being ignorant, i was making a joke; ignorant is not being able to differentiate between a joke and serious comment
SuprAng
Garage Queen VV
Apr 4, 2005
112
Toronto, ON
1000 here 200 there 500 there it adds up. In the end you have a crappy pos with really nice springs lol. Your life is at stake with every mod. Even more so with old parts. And even more so with bad driving.
So in conclusion ... what the fuck do i care, i have coilovers :p
Supra-K
233
Victorville CA
I help a neighbor, cutting 2 coils is to much, but if you cut one and make the top flat, I really dont know how else to descibe the top but as flat, you'll get a pretty good look, as of the back I dont know we just did the front.
Supra-K
233
Victorville CA
actually ill be cutting mine prbably this weekend Ill let you know how it turns out, o and it handled and felt way better when we did it on my neighbors supra
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
hey thread revival :) i hate the idea of cut springs. so... ghetto... its like putting a sock in your cold air intake because you dont want to buy a filter and hope that the socks will keep the water out while letting some air in
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
One and a quarter coils, and make sure you DO NOT cut the smaller diameter end of the coil spring.
Also, use an angle grinder or a pneumatic grinder/cutter and keep the coils cool with water so you don't heat them up and wreck them. Do not use a torch.
