CT 26 Trims physical differences??
turbogeek87
turbogeek87
Mar 29, 2006
Juneau, AK
I bought a rebuilt ct-26 several years ago with a few miles on it and it has been in storage. Since then, I do not remember what outfit rebuilt it or what the trim was. All I can remember is that it was a "slight" upgrade, so it's probably not a 60 or 57 trim.
I copied this list from SUPRASTORE cause it seems to be the most extensive list of trims I could find.
46 Trim: 41lb/min or 410hp
50 Trim: 47lb/min or 470hp
54 Trim: 45lb/min or 450hp
57 Trim: 49lb/min or 490hp
60 Trim: 50lb/min or 500hp
60-1: 61lb/min or 500++hp
Is there any physical differences between these that I can look for to ID the specific trim?
radiod
1,342
Abbotsford, BC
You won't be able to see the difference from the housing, no. You MIGHT see a difference if you look at a stock and a larger trim one side by side if you look at the fins, but it would depend on how big of a trim the new one is.
On the other hand, I have seen a few that have been stamped with the new trim size on the turbo housing. That would be the only easy way I could think of identifying it without measuring, and it's definitely not going to be on every single rebuilt CT26.
iirc stock has 5 blades and the upgraded have 6 blades + the inlet will be bored out. you could measure it to find out for sure.
also your not going to get 500hp out of a ct.
paradox616
472
Melbourne, Australia
i imagine that the comp housing will be bored out to fit the larger wheel,
here is a picture of my ct26 and ct26 57trim side by side.. it may help you identify what ever it is...
turbogeek87
turbogeek87
Mar 29, 2006
Juneau, AK
Thanks for the responses. Hopefully it is stamped, I'll take a look see. I already looked for a tag, but I didn't think about it being stamped.
Dakar2008
nookie
Aug 16, 2006
59
chicago, il
i have a 47 trim wheel, but the blade size is 2.1875 inducer and 3.1875 exducer which is wierd, wheel is much bigger than stock, but pretty much same trim.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Thats larger than a 57 trim. Appears to be 60-1 or larger.... Although the 60-1 has almost nearly vertical fins.
