Cross-compatible radiator fans?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,265
58
Atlanta
I tried a quick search on this, but wasn't sure of what terminology to use:
I'm wondering if anyone knows of any compatible fans from other Toyota/Lexus models, that could be used on the supra. My clutch is fine, but the blades themselves are kinda ratty. i just wanted to know if anyone had experimented with other part numbers, and found similar diameters. For example, i pulled the fan off of an LS400 the other day, but its about a full inch larger in diameter, and wont fit the shroud. However, it mounts just fine to the clutch, and i imagine that holds true for nearly all Toyota fans used on logitudinally-mounted engines.
Lemme know what you guys have found.
:icon_bigg
bloodasp90
JZwhore of JAPAN
Nov 9, 2007
529
on the river
In my case, just saying, i went and got a new fan blades from DM, plus a new clutch pack at the beginning of the year, never looked back at Efans..
supraguy@aol
Well-Known Member
Dec 30, 2005
4,265
58
Atlanta
Efans?
I would never want an efan.
I ended up doing the same thing- Buying a brand new fan, as well as a brand new fan shroud.
bloodasp90
JZwhore of JAPAN
Nov 9, 2007
529
on the river
well like you said the shroud is the hole stopper.. if someone could come up with a shroud to fix a bigger fan.. i know id buy one.. lol
supraguy@aol
Well-Known Member
Dec 30, 2005
4,265
58
Atlanta
I have a feeling that even a 1inch increase in diameter would require a shroud that would interfere with the hood.
But all's well that ends well.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,265
58
Atlanta
Just wanted to add a pic:
The Lexus LS400 fan is BARELY smaller than the shroud opening, but IMO- too tight to safely run. If someone were so inclined, they could certainly shave a 1/4" from the blades to make it a perfect size.
The problem with that of course, is getting it perfectly balanced afterwards...
