crankshaft removal
Mischief7m
Broke and Lovin It
Sep 13, 2007
507
Central Ma / Cape Cod Ma
im just about done pulling my crank shaft, but im having a few problems. first, i cant get the final bolt out of the flywheel, but thatll be solved when my friend shows up with his impact wrench. but the thing i cant figure out is how to get the crank pulley off. i have the bolt out of it, but i cant seperate it from the crank. anybody have any tips?
thanks
Mischief7m
Broke and Lovin It
Sep 13, 2007
507
thats gonna be difficult. ive already gone after it with a prybar and rather large hammer....its on there good enough to have cracked part of the pulley right off. luckily i dont care about it. because im much of it is about to go to scrap metal.
Mischief7m
Broke and Lovin It
Sep 13, 2007
507
hmm well i have nothing resembling that tool haha. but i guess that all i was checking was that all i have to do is take out the bolt. then it should just pop off. theres no secret pins or anything holding it on. i guess ill just go pound on it some more.
thanks
Whasian
CEO of HAS
Jun 12, 2007
148
Houston
It should pull right off. Try tilting the H/B up and down. But be careful not to break anything off that balancer, it is weighted.
Whasian
The balancer is PRESSED ON when you tighten the bolt (hence the very high torque spec for the bolt)
Use a puller like you're supposed to so you don't break stuff.
I ALWAYS use an impact to remove the flywheel bolts as I use red loctite to make sure they don't come out.
