Crank talk
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
lol yah my eng was swapped sometime in the past it has a 6m stamped crank in it hmm wonder why tho to an older one my car is a 90
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
GrimJack said:
Not to worry. The 6M version weighs less and can be revved higher. :)
Oh wise one tell us more...
seriously, how much lighter? stronger? weaker? Why higher revs, is it just the lighter weight? Love to know any info you might have on crank differences. :icon_conf
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Actually, I don't really know that much about it. The rev limit was dropped with the heavier crank, but the reason behind it really is a guess on our part - more rotational mass means it't tougher to spin up and down in speed.
It should be several extra pounds, as the 7M has 2 extra counterweights.
JT87NA
SLC, UT
I believe the 7m crank is around 5lbs heavier then the 6m crank... I have both sitting in my garage right now, I should weigh them. Although my 7m has been balanced so some weight was taken off.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
I agree, I am about 97% sure the 6m crank weights in at 52 lbs and the 7m weights 57 lbs. Although, I have heard that the 7m, due to the extra counter weights, is better balanced. I run a 6m tho :icon_razz
eric
cruzinbill
SC3TT
Jun 26, 2005
515
Arkansas
well im actually glad i have the 6m crank now since im building a hi reving application well now to get some rods and get the whole assembly balanced yessssss
JT87NA
SLC, UT
If you are getting the whole rotating assembly balanced it really shouldn't matter what crank you are using.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
cruzinbill said:
it should still help being lighter, plus what is anyone 2 cents on knife edging the crank has any done it with this eng
It's been done, although rarely. If you are going to fully balance it, might as well do this as well.
While you are at it, think about adding a crank scraper as well...
