crank pully help
mshaw067
I am changing my timing belt. Last time i did this when i rebuilt the engine I had an impact and now i dont. Thats not my problem how do i get the crank pully to stop turning. I have tries a screw driver a piece of wood, I am running out of ideas. last tiem i uses the screwdriver and an impact. worked well now i am reduced to a 3/4 socket and a 1ft bar...........
MKIIISupraGuy
639
Lousy-ana
If you had a breaker bar, or some kind of pipe you can slide over your ratchet, you could brace it against the ground/floor and bump your starter over to get the bolt loose.
mshaw067
no i broke the bar today, so now i have a ratchet and i took my car off the ramps, and i have 2 2by 4 bords that are going with wise across the front of the car and i put the ramps under the crank to support the wood. i already broke one ratchet today and going to try another tomarrow. what other sizes fit the crank bolt?????
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
I don't understand what you are doing.
And what do you mean by other sizes?
mshaw067
like what is the same as a 3/4th socket. I am having to use a tiny racket and it is not working i broke it. I have a large racket and but none of my sockets fit the rachet head. i have wood on ramps under my car trying to provide ground so the rachet will not turn when i bump the starter to break loose the pully bolt. so far no luck and i dont know what to do next i dont want to break all my ratchets and i dont have any more pipe
Smartparts
146
CT
you really should be using a 19mm socket on a 1/2" drive breaker bar. I broke a ratchet trying to use 3/8"
Aug 12, 2010
347
P.G. County, Maryland
ForcedTorque;1680148 said:
From all I have heard here, I must question if you have a puller to get the pulley off, or will you just use a hammer?
Mine slid off easy, i just pulled.
---------- Post added at 10:36 PM ---------- Previous post was at 10:35 PM ----------
If your car is a 5=spd just put the car in gear. Mine was an auto so i just grabbed the outer ring of the pulley with a 48" pipe wrench and used a cheater bar lol. I bought a new one anyways, so i didn't care.
Poodles;1680192 said:
If it just slid off, you have issues...
How so? They slide for the most part back on and most import cars they can just be wiggled off. IF its rattling loose yes.
You NEED a 1/2" 19mm socket and a 1/2" breaker bar. Its torqued to 198ft lbs. It shouldnt come loose easy.
