Crambo's V12
I wouldn't suggest driving at night, the optics on the fogs aren't designed for headlight use at all regardless of the light source put in them.
Crambo
17
Victoria
Poodles, I'm well aware of the headlight compromise, I would not recommend anyone do this modification.
The car is being built as a curiosity rather than regular use vehicle, the engineers will most likely defect them,
give me 1/2 an hour and the stockies will be back in.
I'd have to take a look at the stock fogs (my bro has a MKII) and see what I can do. If I could find a clear glass lense without the flutes I could probably make them functional for headlights :)
Crambo
17
Victoria
The lense is a flat rectangle, getting some flat glass cut should be simple,
something to check out if the need arises.
Crambo
17
Victoria
I'm only a country boy, so I'm a bit slow,
engine bay is missing some cylinders ATM.
Altered the front a bit from stock.
I do plan to finish this car one day!
#04
526
Cambridge
^this MK2 seems to have just the right amount of 'insainity'...inside...
G/L with this beastly beauty
boostcraver
372
Louisville, KY
Un-f***ing believable! Too bad I can't use my sound on the pc right now...would really like to know how it sounds! Keep it up and DON"T FORGET TO UPDATE!!!
Crambo
17
Victoria
Still on the go, but don't you guys hold your breath waiting for a finish.
Rear lip is tilted forward and raised 2"
