Ive recently essembled a block.seamed to have a slight mis before the first five hundred mls.then the dreded hydrolock. so question? could you crack the clinders buy to mutch heat?yes 5 and 6 were cracked at the water jackets locations.the scoop, head is milled to .0022. 1mm head gasket,creamic rings,and around 800mls did boost 12lbs.so did i gernade this mtr.thanks for all your opinions. :nono:
