CPS wiring
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
I messed up the CPS wiring when i took out the pins out of the male side (off the harness). Two wires where hanging on by only one strand.
I was wondering if anyone knows witch go to witch THANKS
Female - 1.Orange 2.Green 3.Yellow 4.Brown
Male - ?Brown ?Black ?Gray ?Orange/red-ish
Note: this is for a 88 turbo, 89+ is different
erifann
Accidental afficianado
Apr 18, 2007
North Cackalacky
Usually, if you just let the wires align themselves, expecially old ones, they'll tell you where they need to go. If not, I'll look at my 87 manual when I get a chance and let you know what I see. I had those wires come out before, and we ended up hardwiring the thing... bad idea without some serious heat insulation!
Peace,
Erik
shaeff
Kurt is FTMFW x2!!!!
11
Around
Harness side / CPS side
Red / Green
Blue / Red
Black / White
Yellow / Yellow
-shaeff
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
Shaeff! i've seen you much on the forums and add much.... but you posted the same thing in the other forum too! lololol
Thanks, but those are not the colors for my Cam Position Sensor.. Thanks tho!
NOTE: 88 turbo (different from 89+, but same as 87)
Merlyn
162
Maryland
Yea, I was about to say... I manually wired my CPS... and Shaeff is correct...
one wire may look blue... but if you trace it in the harness, it is green
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
88 and 89 are different.. antman Has to have an 88-, The colors are way off... i looked at the wiring diagram and Shaeff was right... but its for a 89+. And i could not find a 88 wiring diagram for the likes of me.
Jason T
JZS161 Aristo TT
Auckland New Zealand..Aotearoa
Both combos
tte
Breaking In - in progress
Northern California
I think you would want a connector that is water proof...
You could always use a molex connector and put silicone on the black so water does not go in or use insulation tape.
Cheers,
Roy
