CPS wires giving me trouble
93redrocker
7
Washington
Every now and then my supra will not start because of the cps wires, I have to go out and just wiggle them around and then it will start right up every time, its getting old, It looks like someone has respliced new wires at one time to the little harness that runs into the sensor itself, but they soldered the wires together, so it was done kinda right. can the splice in the little wire harness be part of the reason as to why I just need to wiggle it around or do these sensor get loose connections in the sensor itself. Anyone had this problem before?
I am also looking for a new little wire harness for the cps sensor to replace if some one has it.
figgie
Twin Cities, Minnesot-ah
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
You may have corroded soddered connections. Take off the electrical tape on there and check it, you may want to re-do it yourself. If there is more wrong you may want to get a new cps.
grimreaper
2,180
Dallas
figgie;1145798 said:
Well
my first concern is what type of splice and crimper for the splice was used.
More than likely it was the NAPA/Radio Shack crimper that work but not very well. For a good quality crimp splice requires
[thumb]http://www.supramania.com/forums/attachment.php?attachmentid=23468&d=1217471892[/thumb]
anything else and the splice will fail. Sodlering. The area around there is to heat prone for soldering. Cranking, no wire stress relief etc. Not such a good idea.
:bowdown: solder no bueno under the hood.
93redrocker
7
Washington
Poodles;1145859 said:
Dunno where you would fit a splice in the first place, that area is cramped as hell as it is...
Anyone know were to get one for less then 500.00?
All parts houses what about that much for the cps
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
i had the same problem i bunt connected the 4-5 wires i think. For the cps and my idle has improved but i need a new cps anyways cuz when i removed the dust cover it was all rusted inside so the idle still goes up and down but not alot!
try to bunt connect them i know its hard but if i can do it so can u!! all of the wires run into the MAin harness i believe! GOOD luck bro
ForcedTorque
Join the 92 Owners Group
6,099
I have a source that sells refurbished ones and warranties them for 30 days. Comes all cleaned up inside and out, new cap, new gasket, new O-ring, and greased with a white lithium grease. He wants $125 + shipping on them. Here is a picture of what it will look like:
Scott - Does he replace the internal seal and bearing? How about the gear?
ForcedTorque;1146033 said:
but he's old, maybe he forgot to list it.
LOL...suffer from CRS myself ;)
(who are you again?)
If he replaced the internal bearing and seal, that is a very good deal!
bowsercake
828
Irvine, Ca
I recently bought a new one as well, it was very expensive. But I just got a job so that's where some of my bonus went haha.
93redrocker
7
Washington
Thanks alot for your help, I will give it a try!
93redrocker
7
Washington
I am going to check with my toyota dealer as well to get a price for a oem one.
93redrocker
7
Washington
Can you give me anymore info on that, I am interested.
