CPS misalignment?
Greykier
14
Dallas,tx
I am finishing a build on an '89 turbo. I managed to get the car running, though not well: it would not idle, and would run quite lean under throttle. Upon trying to adjust ignition timing, I discovered the CPS range of motion would not allow anywhere near proper ignition timing. I checked the CPS driven gear alignment and found it was off. I restabbed the CPS, per the TSRM, and now she won't start at all. I get sputtering and a few deafening backfires. I have rechecked the alignment twice with the same results. I rechecked spark, fuel delivery, and vacuum system. I am suspicious of the CPS. Is it possible for the CPS to suffer an internal alignment failure? If so, what's the fix? I have tried the wire wiggle thing to no avail. Any help is greatly appreciated as I am about ready to put a bullet through the block and buy a bus pass...
shaeff
Kurt is FTMFW x2!!!!
11
Around
Check cam/crank timing. Make sure that when the crank is at 0*, that both cams have the notches pointing at 12 o'clock. Pull #1 spark plug and confirm that the piston is in fact at top dead center, and that the crank pulley is tight and has not slipped.
When the cams/crank are at 0* TDC, THEN install the CPS per the TSRM instructions, or the instructions found here:
http://www.supramania.com/forums/showthread.php?t=38775&highlight=install+CPS*
Greykier
14
Dallas,tx
I already rechecked timing belt alignment just before reinstalling the CPS (at cylinder 1 TDC.) I did not, however, check for MIL codes. I will post my findings in a moment.
shaeff
11
Around
Did you jumper t(e)1 and e1 when setting IGN timing?
Greykier
14
Dallas,tx
Ok, here are the codes and my theory for their presence:
code 14: Ignition coils unplugged while testing compression.
code 51: TPS unplugged while checking ISC valve operation.
I rechecked the connectors just now, all contacts ok.
shaeff
11
Around
No, I mean when setting the ignition timing, you need to have those terminals jumpered.;)
Greykier
14
Dallas,tx
Yes, I'm sorry, I wasn't clear. when attempting to set the timing, I had those terminals jumped. I had a friend in the car trying to hold the idle manually, while I tried to set timing. It seemed if I had been able to turn the CPS another 90 degrees (+/-) beyond the flange limit, it would have been dead on.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
It's unlikely in the extreme that the CPS has suffered something internal. It's pretty easy to check, though - pull it and inspect the gear. The gear is held in place by a pin, and unless that pin is obviously messed up, the alignment has to be good. The shaft is more than tough enough to do some *serious* damage before it would twist.
Can you post the procedure you used to check your timing belt alignment?
Greykier
14
Dallas,tx
Cylinder 1 TDC (compression stroke); pulled #1 spark plug, inserted length of rubber hose to feel compression, used video bore scope to inspect vertical movement of piston, verified with crank pulley mark at 0.
Timing mark alignment; removed upper timing belt cover, verified marks on camshaft sprockets aligned with notches on rear sprocket cover.
rotated crankshaft clockwise two complete revolutions, reverified all timing marks.
I will recheck the CPS alignment again to make sure I was looking at the right thing. (self doubt has set in with a vengeance)
Greykier
14
Dallas,tx
well...
good news and bad news.
good news is I won't be getting a bus pass.
bad news is I won't be getting a bus pass because I probably would try getting one at an airport bar.
After ripping my hair out trying everything but the obvious, she's a runnin' strong. I pulled the CPS and restabbed. She started right up. Evidently, I aligned the driven gear pin, instead of the drill hole, with the groove on the housing. :kickinthenuts:
Thank you very much for the help. I believe I just needed a third party observation to re-center my logic. Thanks again for the advice. Back to lurking...at least i don't have to shoot her.
