1) my horns don't work. I trimeed my hood latch support so i had to disconnect the horns and remove them. Now, they don't work. I doubt it's a fuse because the battery was removed when i disconnected them. What else has to be plugged in in order for the horns to work??
2) my gas gauge sits at empty. I removed it twice now and it still doesn't work. The first time i removed it, i tried setting it back to where it was when i first took it out. So about 3/4 tank full is where the needle was. That's where i set it and then it shot up way about the "F" mark. I searched around and found out that i should've placed the needle just below the "E" mark. I did that and now it doesn't even budge. What gives???
3) my temp gauge reads too hot even though it's not hot enough to reach that high. My autometer water temp gauge hasn't even hit 190 yet, but my stock gauge reads almost 3/4 the way up. I set it right at that line at the very bottom of the gauge. What gives??
These are just ANNOYING pesty little things that are bugging the crap outta me. HELP!
Derek
Derek
