cost of head gasket installation?
tonysupra
224
CT
Does anyone know the range of how much replacing a head gasket will cost?
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
book time is about 10-12 hrs at shop rates(1000-1500$)+-,
a good supra owner can do it in about 5 hrs labor plus parts... i did mine for about the cost of the head set ($250)and to have my valves lapped and valve guide seals installed and valves adjusted.(60$).... and the head surfaced, ($75)
but i also did water pump and timing belt while i was there.. again time and parts extra.
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
BS! these cars never blow head gaskets... :D:D:D
BTW: I agree with Joel... Depending on the shop, anywhere from $1000 and up... Then add in the cost of a metal HG and ARP head bolts or studs... You'll also need a gasket set for all the other gaskets you'll hafta replace when you do a HG swap... *intake gasket, exhaust, tb, and the other hundred or so gaskets, lol*
GL with yur hg...
Jake
lagged
1991 1JZ
new rochelle
if youre going with a MHG and the block will have to be surfaced, pull the motor your self and bring it to the shop your self, save lots of money.
stratoayu
435
surrey
its 8.9 for a non turbo and 9.1 for a turbo i belive. thats from the labour guide. and budget usually around 70 bux an hour for labor.
89Turbo
804
Portland
labor guide from my mechanic said 8 without turbo 12 with, buy im only payin $35 an hour. so my cost in labor is approx $425, but you will never pay this little unless its your friends shop.
