Cooling fan options - Mechanical or Electric
figgie
Twin Cities, Minnesot-ah
jetjock said:
Good. I could use some entertainment.
2nd'ed!!
btw
I run electric fans.. no not the lame-o dual 12 incher barely blow a leaf anywhere slim line crap. The dual 13 inch sucker is what i use. Plenty of room between the frame ;)
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
what, aww come on 14 is that bad? it was at over 20* for god sakes haha, everything feels great now, idles at around 750, course still fluctuates a little, I think my TPS is a little screwy... Ill figure it out.
Why are so many people running 14* advanced though if its that bad?
he's N/A, so you can run that timing, on a turbo motor you're just wishing for a dead engine...
E-fans are FINE, as long as you don't skimp out on them. They'll cool better in stop and go traffic because it's not RPM dependant.
If NOT wired properly, and not sized right or using crappy fans, they're just gonna leave you stranded...
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Thanks, I was wondering how reliable they actually are. I think what Ill do is either replace the 7 blades with another 7 or 10 blade with a gte clutch. When I do my "special project" Ill toss in a koyo rad with e fans.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
OneJoeZee said:
The fan shroud is an integral part of the cooling system..
It broke, never caused a single problem for me other than exposing the fan... I do plan to replace it though. I drover 12 hrs straight to get to where I am now without incident
KeithH
Portland, OR
I'll second that. Try driving up Baker Grade on the way from LA to Vegas. 16 miles straight up. That will really test your cooling system - even before noon.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
IJ. said:
Try driving it on the hottest summer day in traffic with the aircon on and see how it fares ;)
99* outside, 2 hrs in stop in go traffic back in houston, windows up, A/C at 65* medium blast. needle never went up past her usual mark, and the gauge is still working.
dbsupra90
toonar
indiucky
just thought id note- the stock temp gauge is real inaccurate.
yeah, you will know if it has a serious problem, but other than that its far from being realiable. my aftermarket gauge can swing 40 degrees before the stock one thinks about moving.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Im aware its inaccurate and yes I only have a stock gauge but I know it still works, Ive tested a few things to make sure and it will still tell me when its critical. No worries though, next few weeks Ill be picking up new fan, a shroud I hope if I can find one, and 3 new gauges ;)
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Cheap fix and you'll never have to worry about for another 15 years.
Fan shroud... ~45.00.
10 blade fan... ~??.?? check.
Re build fan clutch... ~10.00 yep, check.
Making sure you have the engine undertray... priceless.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Yeah previous owner took out undertray... idiot (him)
Where can I get the fan clutch rebuilt?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Do it yourself. JetJock made a thread on how to do on MKIIItech, it takes around 50mL of silicone differential fluid from an RC car (again, check his thread for the exact weight you will need), a good brand to buy would be Mugen, and can be had on ebay for less than 10 bucks.
evilone
they call me Tatter Salad
Fort Worth
i know you have decided to go with a mech. fan, but i would just like to ask what everyones problem is with the electrical fans.i have a dual elec. setup with a fluidyne radiator and it works perfect down here in texas with all the heat and humidity. i have an autometer temp gauge and when i switch my fans on, it only take about 10 second before i start seeing the temp dropping back down.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
The electric fans do not flow as much air as the stock fan does, You're probably not going to see any issues with your upgraded cooling system, but you may if you drive at high RPMs for an extended amount of time.
evilone
Fort Worth
even at high rpms and high speeds i havent had any issues and i have had this setup for over a year now.either way i guess that answered my question.
figgie
This is contradictory.
Even at high speeds, the stock fan will not flow no where near what is coming through the front at a measly 40 mph much less 100+ MPH.
