Coolant coming from behind my center console
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Hi everyone! As some of you know, I just repaired a BHG about 2 weeks ago. I'm guessing the heater core sustained damage when the BHG happened and is now leaking. I have been hunting this coolant leak for about a week now and just found it today. It's leaking just enough to wet the carpet slightly.
I have never changed one before and a quick check of the TSRM didn't reveal the heater core location.
Here are my questions:
How difficult is it to change and what is the approximate job time?
Where have y'all been purchasing heater cores from? (please don't say Toyota!) :D
Could it be something other than the heater core leaking behind the center console/dash?
Thanks...
-Kenny
CajunKenny
Nov 15, 2007
3,255
Washington
Oh great! That's all I need! Another HUGE-O-LA project! I just got done with the BHG for pete's sake!!!!!
Aaaaarrrrrrgh...the life of a Supra owner...bitter-sweet! SIGH.... :)
Davismj711
PA Mountain Supra
I recently did a complete tear down of my donor Supra. I believe you would have to remove dash ans even the dash support to R&R the heater core. Keep in mind I was stripping a car, so I didn't bother to read my shop manual.
I do hope there is an easier way. But from what I saw that was the only safe way ( keeping new core unbent etc ) to install it.
Good Luck to you Kenny, or should I sat I hope you are blessed with an inordinate amount of patience.
Mark D
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
you can bypass it for now if you need to use the car before you have time to fix it, bad idea to drive with it like that, you will get air into the system
CajunKenny
Nov 15, 2007
3,255
Washington
You guys are scaring me!! lol... :)
Well, I'll try to pick one up locally and get after it!
May the Supra Gods grant me with Supra Knowledge, Supra Guideance, and Supra Patience! :D
CajunKenny
Nov 15, 2007
3,255
Washington
Hey Matt. Yeah, I'll let ya know. Thanks man!
Do you ever make over this way? I sometimes head out there. We should hook up for lunch or something!
Justin
Speakers?
Spokane, Wa
how will air get into the system if the heater core is bypassed?
CajunKenny
Nov 15, 2007
3,255
Washington
Poodles;1134390 said:
Could be the extension pipes used on the LHD cars as well...
Are these extension pipes something I can check without pulling out the dash?
Is there anything else I should check before I remove the dash or while the dash is out?
CajunKenny
Nov 15, 2007
3,255
Washington
Thanks for the suggestion; but, I think I'd rather fix it while the weather is half way decent. It'll be turning cold here soon and I won't want to fix it then. Plus, I'll be wanting HEAT!!!!!!! :biglaugh:
CajunKenny
Nov 15, 2007
3,255
Washington
Ok. I just thought of something. I have the temperature control set to 65 currently. Does that mean that there is NO coolant passing through the heater core?
If there's nothing passing through the core with it set to 65, then what could it be?
I guess I'm thinking of the good ol chevy days where the temperature control was connected to a valve via a cable and the valve controlled how much coolant made it to the heater core.
