do you have a barbeque grill? if so there are lots of easy to do recipes there. one of my favorites is grilled chicken breasts marinated in garlic butter with grilled fresh corn on the cob.
to accomplish this preheat the grill to about 300* , then turn one burner off. place the corn cob/cobs with the leaves still on 3/4 of them (its better to do two) in tinfoil shiny side in leaves down. place about a teaspoon of butter and whatever seasoning you like (i usually just shake a little pepper, lemon juice, and some garlic salt on mine) in the tinfoil with at least two fullsize ice cubes per cob and seal. place the corn on the bottom rack directly above the burner that is still going. you want to cook the corn for about 1/2 hr so plan accordingly... do not disturb the corn! then with about 15 minutes left on the corn place the chicken breasts on the top rack above the corn. cook them till done throughout turning halfway through as to not burn.
when removing the corn from the grill, be careful not to break the tinfoil seal as the butter will flair up. also be careful when opening the tinfoil as it will be full of very hot steam.
enjoy! this can also be done with steak, but cooking times will vary. and the steak should be grilled on the bottom rack beside the corn. if you cant grill steak.... you are beyond help.
---------- Post added at 10:44 AM ---------- Previous post was at 10:37 AM ----------
damn now im hungry..... off to the store for supplies!
