My compression tester is stuck in the #1 spark plug hole. Its the threaded type with the O-ring seal. Any idea how to get this thing out without taking the engine apart. Compression was 185 BTW.
BorHor said:Oh no. I wanted to use it too! Hope you didn't cross the threads.
How did you tighten it down then?Yellow 13 said:The problem is the hose spins independant of the threaded part.
97TSiAWD said:How did you tighten it down then?
jdub said:I'd sacrifice the tester before I took the head off. Could you get a socket over the thing if you cut the hose off even with the spark plug well?
Yellow 13 said:Im just gonna get another HG and some ARP headbolts. I planned on pulling the engine up to do that pilot bearing like I shouldve anyways.
Ive at least got the piece of mind knowing that it fired up and ran.
