I'm using a 1J head on a 2J-GE block, and I have a choice between either a stock 1J headgasket, or use the 3mm HG (8.3 ish : 1) I have from cometic. I am running 274 degree 10.3mm lift cams with 1mm OS intake valves.
I'd like higher compression (9.2:1 ish I think) with the 1J headgasket but how safe is this compression under boost with say a GT40R on 93 octane with a Blitz tuned ECU for 550cc injectors ?
Would my max PSI change since I'm using the 1.06 housing?
-Or-
Would it be a lot better to run the 3mm HG?
I'm going to wait and use the stinger later on. I want to enjoy my car right now The head is not on the car yet.
-Or-
