Compression Check Results
Bigdough666
Picture Me Rollin
Apr 4, 2005
367
Corpus Christi, TX
Did a compression check on the Supra yesterday since Ive been getting some extra pressure in the crankcase (blowing off vacuum lines). Here are the results:
#1 - 155 , 160 w/oil
#2 - 160 , 165 w/oil
#3 - 160 , 175 w/oil
#4 - 150 , 160 w/oil
#5 - 150 , 160 w/oil
#6 - 170 , 180 w/oil
So how does it look? Not too bad I guess, I was expecting worse. But it does seem like the rings are worn out. I guess its not too bad considering Ive been beating the hell out of this engine since I last built it 3.5 years ago. I think its time to pull it out and freshen it up, new rings and bearings. While Im in there, get the head worked - cams, bigger valves, etc, etc. Non stop with these cars.
Doward
4,245
Alachua, FL
Range of 150-170psi = 20psi, which shows you with just over 10% difference. You're still 'OK' with the engine.
You say you are blowing off vacuum lines. Can we get more information on this? Is this while NOT under boost? How much boost pressure are you running? Which vacuum lines are blowing off?
Bigdough666
Picture Me Rollin
Apr 4, 2005
367
Corpus Christi, TX
Check this thread for more info on the vacuum lines.
http://www.supramania.com/forums/showthread.php?t=96210
Technicly it's out of spec as it's supposed to be within 14PSI of eachother...
Leakdown check?
and #6 is the oddball...
