Composite head gaskets - Toyota vs Fel-Pro
Doward
4,245
Alachua, FL
I'm still swapping head gaskets (got the felpro in, got the head torqued currently to 100ft/lbs on 30wt oil) but I've got pics of the FelPro.. yeah, it's not a solid metal gasket like a true MHG, but the area around all 6 cylinders IS metal... I'll have pics later tonight on it!
dbsupra90
toonar
indiucky
wow 3 pages since i posted haha.
i should have clarified. fel-pro didnt make the original hg. only the "redesigned" one later. i do not know 100%. i didnt go knock on their door and ask. but several people in the know ive talked to have all said this. take it fwiw.
Doward
4,245
Alachua, FL
As promised -
TOP
BOTTOM
americanjebus
Mr. Evergreen
wa.
i've run felpro head gaskets on 3 different cars from 3 different countries, as long as you prep the surfaces right they will stand up to the job. 10k miles so far on a felpro in my supra.
89Turbo
804
Portland
thats all i was lookin for i was gettin a little scared that i went with a Fel-Pro, how much boost do you run daily?(or however often you drive it)
americanjebus
Mr. Evergreen
wa.
i drive with about 8-9 psi hitting boost wherever i can pretty much every day of the week. waiting for some time and $$ to hit 12psi and im not worried about my hg.
Doward
4,245
Alachua, FL
Tuned on stock afm/injectors? What was your A/F ratio, under part throttle boost? (where I've got a theory most of the light head-gasket-damaging-detonation is occuring, with elevated boost levels)
Yeahdoug
53
Rochester Hills, MI
Yes on stock AFM/injectors. 440s are plently for stock turbo.
11.7-11.8 full throttle, Never above 12.5 under any kind of boost.
Doward
4,245
Alachua, FL
I'm going to file that little bit of info away... I'm going to do some wideband runs on the stock tune before adjusting anything, and see what Toyota deems necessary for AFR under boost....
When you torqued the stockers to 75 ft/lbs, what did you use for lubricant, or did you install them dry?
Yeahdoug
53
Rochester Hills, MI
Had some of that ARP moly left over from another car...
I actually had to pull fuel out of the car. It was really rich stock.
